17-04-2012, 09:33 PM
17-04-2012, 09:43 PM
You know you calling me that will only bring a response and will exacerbate the situation as there is now another one for the tally...
18-04-2012, 01:12 AM
f*ck me dildo, thats a big word!
also, scott, cant believe how straight this is, cracking find!
18-04-2012, 04:45 AM
Well it's the colour of gods but engine of a mere mortal!!!
18-04-2012, 05:14 AM
Looks cracking does that, I'm starting to think you, Kim, Ed and Foobs have just decided to buy every '6 in Britain
18-04-2012, 07:32 AM
18-04-2012, 08:06 AM
Haha, good man, you know it's right to be back in a '6. And what a '6... :drool:
18-04-2012, 08:31 AM
Looks awesome buddy, best model with one of the best colours going. Winnar
18-04-2012, 10:12 AM
So essentially... Scott's bought a new car, and it still doesn't have a turbo on it....
BORING!
BORING!
18-04-2012, 10:25 AM
18-04-2012, 08:50 PM
Ruan Wrote:So essentially... Scott's bought a new car, and it still doesn't have a turbo on it....You'd hate me more if I bought a VAG though...
BORING!
Cheers for the compliments It has a couple of little niggles. Firstly the exhaust is blowing and knocking slightly, and the clutch is a little stiff, so I'll give it a try changing the cable first, if not then it'll be a clutch change down the line (don't want to end up causing more damage to mounts and bushes from excessive juddering when pulling away or engaging a gear). Also the drivers seat has a hole in the alcantara, so that will either need retrimming if I can get a good price, or a new set will need buying.
Other than that, I'm very happy with it! I'll be much happier when I've got my Turinis back on though, with the Eagle F1s, as the budgets are fairly understeer-y.
I should have the turinis on by the weekend following my cambelt change, plus a service on Sunday if I get time, then next month I'll be hoping to get it lowered after payday in time for FCS!
18-04-2012, 09:19 PM
Scott Wrote:and the clutch is a little stiff, so I'll give it a try changing the cable first, if not then it'll be a clutch change down the line (don't want to end up causing more damage to mounts and bushes from excessive juddering when pulling away or engaging a gear).
Those symptoms..... they're so familiar..... now where have I heard them before? :think:
18-04-2012, 09:20 PM
Hence me getting it done quickly if that is the case
Cable probably won't help with stiffness. More than likely the clutch arm bush which is a box out job. I found a squirt of wd40 helped but only as a very short term solution.
18-04-2012, 09:28 PM
Scott Wrote: Hence me getting it done quickly if that is the case
Yeah last thing you want is the exhaust knocking tragically every time you start/stop/rev the engine.....
19-04-2012, 07:30 PM
yeah. If anyone happens to have a standard exhaust going cheap (or even something like a magnex ) then please drop me a PM! It'll need sorting fairly soon.
Plan for this weekend:
Saturday - Taking the car for the cambelt change
Sunday - cleaning/polishing/waxing turinis and fitting, possibly service Kim's car.
19-04-2012, 07:36 PM
Scott Wrote: yeah. If anyone happens to have a standard exhaust going cheap (or even something like a magnex ) then please drop me a PM! It'll need sorting fairly soon.astor on astor(ish) turini's WILL be epic WIN
I'll make a cheesecake......so definitely servicing my car?
19-04-2012, 07:37 PM
Ed Doe Wrote:Scott Wrote:and the clutch is a little stiff, so I'll give it a try changing the cable first, if not then it'll be a clutch change down the line (don't want to end up causing more damage to mounts and bushes from excessive juddering when pulling away or engaging a gear).
Yeah defo wise getting it changed cos the judder can help towards snapping the welds on your cat (twice)
Kimmie Wrote:I'll make a cheesecake......so definitely servicing my car?yeah kim your in for a good servicing! lol sorry couldnt resist
19-04-2012, 07:54 PM
nice find mate. thought china was my favorate colour but might have to change my mind on that.
19-04-2012, 08:02 PM
4WayDiablo Wrote:Wait til when I get masksScott Wrote: yeah. If anyone happens to have a standard exhaust going cheap (or even something like a magnex ) then please drop me a PM! It'll need sorting fairly soon.astor on astor(ish) turini's WILL be epic WIN
Cheers Kingy
Haha that's right Chris, definitely don't want that! How long have you got Sam's welder by the way? May need a short term solution if the holes/breaks are fairly bad.
19-04-2012, 08:09 PM
whatever 306 it is i think it should have a set of ph3 black masks (or similar colour) so thats a given
20-04-2012, 01:08 AM
just gunna dive in... you can have the welder as long as you need really, i wont have any need for it till after my exams and that are done, so that gives you till june!
21-04-2012, 05:36 PM
Cheers Sam Chris I may enlist your help next week to get the exhaust sorted
Cambelt and aux belt were changed today. I feel much better knowing it's been done now as it was on 34k on the same belt. the aux belt was actually pretty close to snapping! Lucky I'd taken it in Also the coolant was changed and the system was bled.
Turinis should be going on tomorrow
21-04-2012, 05:45 PM
How much did that cost you? I was going to take mine to a garage to be done but glad I didn't. It's supprisingly easy to do actually!
21-04-2012, 05:53 PM
£240, which is less than Lynx or CG Cars, not to mention I'd have to drive my car to either place which would add another £30-£40 to the cost in fuel.
The mechanic will hopefully be signing up here, but I'll do a quick write up tomorrow as he's n ex-Peugeot mechanic
21-04-2012, 05:58 PM
That's a good price actually for all that work! Can't grumble.
Still think you should of manned up and done it your self!
21-04-2012, 08:15 PM
Very noice mate! love astor 6's
21-04-2012, 08:18 PM
Looks shit!!!
Only joking looks lush bud
