Threads: 170
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Threads: 48
Oh dear.
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
Threads: 170
what?
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 124
26
Car Model/Spec: Megane DCiR
Dont think anyones run one of them because of the inlet tbh
Threads: 136
That inlet would make it very awkward to mount, make sure you know how your going to fit it and pipe it before you go ahead.
Yeah, there's a reason everyone gets the front entry turbos...
Threads: 252
7
Nothing a grinder won't sort
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Threads: 170
04-12-2012, 09:25 PM
(This post was last modified: 04-12-2012, 09:33 PM by karl1989.)
mmmm may sell it
(04-12-2012, 09:20 PM)HDIkyle Wrote: Nothing a grinder won't sort
could do. ill wait for somebody to come along and see what they say
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 155
11
Car Model/Spec: Bianca DTurbo
Who did you buy it off?
Threads: 170
04-12-2012, 10:03 PM
(This post was last modified: 04-12-2012, 10:07 PM by karl1989.)
someone of the forum
Ph3 perv cab heaven
Black ph1 XUD died
Its the subaru one with the side entry...bitch to fit as it is
Threads: 170
not sure what im guna do with it yet. will it hit the bulkhead?
Ph3 perv cab heaven
Black ph1 XUD died
Possibly...more of an issue is the inlet pointing 90degrees the wrong way!
Pics before purchase ftw!
Threads: 226
24
Car Model/Spec: A3 TDi
You could put a seive over the end and live dangerously
Threads: 252
7
Can't you just get a housing off a f*cked turbo and pop that on while its been clocked?
Blaze 1.6 Dead
Car Model/Spec: 306 D Turbo
(04-12-2012, 10:51 PM)HDIkyle Wrote: Can't you just get a housing off a f*cked turbo and pop that on while its been clocked?
If the cartridge is in good condition then this is what I would do, otherwise just stick it on ebay and except you may make a loss on it
Threads: 252
7
05-12-2012, 10:01 AM
(This post was last modified: 05-12-2012, 10:02 AM by HDIkyle.)
Just battery mount it!
(04-12-2012, 10:44 PM)Tom Wrote: You could put a seive over the end and live dangerously I did mention this myself, anyone running like this as I know a lot run no filter so atleast big stuff won't get in
Blaze 1.6 Dead
Threads: 124
26
I dont run a filter on mine, the only issue i can see is the inlet would be pointing towards the bulkhead, IMO may be more likely to pick something up but would be tight against bulkhead too is say,
I dont know how grinding it back would go as youd probably be best grinding halfway through the 90
And as for swapping the inlet housing it has to have the same wheel etc
Threads: 170
(04-12-2012, 10:55 PM)londondan86 Wrote: (04-12-2012, 10:51 PM)HDIkyle Wrote: Can't you just get a housing off a f*cked turbo and pop that on while its been clocked?
If the cartridge is in good condition then this is what I would do, otherwise just stick it on ebay and except you may make a loss on it i wont make a loss on it . cant be botherd gear box mounting.
(05-12-2012, 10:21 AM)CJ_Derv Wrote: I dont run a filter on mine, the only issue i can see is the inlet would be pointing towards the bulkhead, IMO may be more likely to pick something up but would be tight against bulkhead too is say,
im thinking of grinding it down abit just so it misses bulkhead if it touches. might get some strong mesh with little holes so it wont suck anything in
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 226
24
It doesnt stick out any further than the rest so i wouldnt of thought it would catch :p
