dash clocks
dash clocks
ive kept taking the hs fuse in and out and nothing was happening also bent all the individual clamps together to make a better connection and its still the same . were u taking the hs fuse out while the engine was runing ???
I had the clocks out mate and no the car was off i just kept fiddling around with it till the central locking was locking its self , which one did you take out the one in the engine bay or the fues box one? I kept fiddling with it up and down takin one pin out and just messing around because i was confused.com i know it sounds silly but it worked
[Image: jhhjjhjhjh.jpg]
i kept fidling with the hs fuse with no rating in the fuse box in the car
Hmmmm Confused could you hear any interferance in the speakers? I could with mine have you checked all your grounds aswell? Also how's your door loom?
couldn't hear no interference, no i haven't where are the grounds, yeah the door loom is fine elecy windows and mirrors work cheers
There's 2 on the chassi leg under the battery tray there's 1 under the drivers footwell and I think there's a few more I had cleaned them up anyway but I'm sure the hs fues had done the trick for me Confused
Hi, i'm having the exact same problems with my clocks. Did anybody ever find a fix?
  Dash clocks resetting? Frosty 14 3,191 14-09-2015, 09:12 PM
Last Post: cheapo
  dash clocks! gurj306 23 6,939 30-03-2013, 03:15 PM
Last Post: gurj306
  Dash Clocks Help C2K 12 2,960 19-10-2012, 12:52 PM
Last Post: C2K
