25-10-2012, 10:37 AM
(This post was last modified: 26-10-2012, 06:40 PM by cwspellowe.)
Right after having no luck in finding the torsion bars I want/need, i've made a few calls and can now offer a group buy on custom torsion bars for the 306, but can also include them for the 106 and 205 ones too.
Your choice of size, however thick you want. Anything over 23mm will need the trailing arms to be removed as the bar won't physically fit through the splined holes, but the splined ends will remain the same size so no actual machining work is needed.
Torsion Bars
Confirmed prices for these are £220 a set if less than 5 names, £180 a set if more than 5 names. Any bars over 25mm will come with a surcharge due to the extra material used. Postage works out at £25 a set to your door.
Anti-Roll Bars
Just found out they can also do these, at £90 for under 25mm and £100 for over 25mm
Hybrid anti-roll bars
The fabled hybrid ARB can also be made, the largest you can fit without modification to the trailing arms assemblies. £125 as part of the group buy
These are the same guys that a certain well known performance Peugeot company use that retail at £324 so there is potential for a MASSIVE saving here. To put things in perspective, Peugeot Sport 23.5mm bars were retailed at 200Euros EACH when you could buy them new. Xsara 21mm bars, with Peugeot staff discount at cost + 10% come in at £190 new.
As you can see the prices are exceptional considering you could go as hardcore as 25mm for the same price as new Xsara VTS bars!
Spring rates
18mm 90lb/inch
19mm 110lb/inch
20mm 135lb/inch
21mm 165lb/inch
22mm 195lb/inch
23mm 235lb/inch
24mm 280lb/inch
25mm 330lb/inch
I've also been assured these are multi-stage heat treated and made of the same material as Peugeot Sport bars (EN47 iirc?) so no chance of sagging after a few miles.
As said, without mentioning names, the company they supply has never had any complaints from customers, and these direct from the manufacturer come in at a massive 45% saving
I'm definitely in for a set, add your name to the list if you want some. And remember, this isn't limited to 306's, so share around other forums if you know anyone else with a Peugeot or Citroen that wants a set!
I'm leaving this running for a week or so, I will be ordering my bars on the 31st so if anyone else is in they need to commit for the end of the month.
Right everyone, just off the phone to him.
With regards to sizes:
He's produced the hybrid ARB before so has the exact dimensions to guarantee no modification to fit one. 30mm ARB's will need the trailing arm pins modified.
Torsion bars can be done to ANY size. 21.5mm? No problem. 23.1mm? Sure.
The maximum size they can make the torsion bars in to fit without removing a trailing arm are 23.5mm, the same as the Peugeot Sport ones. The cutaways in the splined sections are deeper than the 24mm diameter so to confirm, 24mm bars will not fit without removing a trailing arm.
If anyone needs to change their order based on this information please copy and paste the list from here with the new order.
He's also said that if I can get the first 5 people paid up he will start work on the orders, so anyone who has paid up can get them straight away.
Please email me at stancewagon@hotmail.co.uk or PM me if you want payment details and to arrange delivery address etc.
PAYMENT (Will update this as we go along)
1. cwspellowe - 306 23.5mm bars PAID
2. Jonny81191- 306 24mm bars
3. Niall - 306 22mm bars PAID
4. c.gerrard - 306 size TBC
5. Matt - 23mm bars
6. lisa306- 23mm..TBC
7. Chris - 306 30mm ARB
8. Grant - 306 24mm bars
9. Sean - 306 23.5mm bars
10. luke306rallye - 306 23.5mm bars PAID
11. puglove - 306 23.5mm bars + hybrid ARB PAID
12. jimmy-boy (106RR) - 106 22mm bars
13. Huliblus (106RR) - 106 23mm bars
At this rate i'll be ordering the first lot tomorrow for anyone that's paid, meaning you should see them at your door mid-end next week. If anyone else is in a position to pay sooner rather than later let me know so I can get more orders in
Torsion Bars
Anti-Roll Bars
Spring rates
18mm 90lb/inch
19mm 110lb/inch
20mm 135lb/inch
21mm 165lb/inch
22mm 195lb/inch
23mm 235lb/inch
24mm 280lb/inch
25mm 330lb/inch
5. Matt - 23mm bars
