catalyst help
catalyst help
I am currently miss firing under 2000 revs when i poke the go pedal will it make my cat colapse i had a simillar problem with my 406 2.0 turbo and the cat collapsed Cus of the unburnet fuel exploding in the downpipe and thoughts will be appreciated
I had a cat collapse on my 1.8 16v so it's not out of the question. If you're concerned about it then don't drive the car until it's sorted.
If it's a missfire then check the sparks first.
[Image: Sig500x130.png]
put a de cat on, diesels dont need them anyway...
(08-10-2012, 10:48 AM)JackLewis_Dturbo Wrote: put a de cat on, diesels dont need them anyway...
This is the petrol section dude lol
Decat would work but you lose a fair amount of torque on a 1.8 - it's quite noticeable. Also it'll get louder, by quite a bit.
A cheap catalytic converter would do the trick...
oops! thought you were talking about a dtub Smile my bad!
sounds like it needs the problem sorting rather than worring about the cat
