19-07-2012, 09:06 PM
(19-07-2012, 05:48 PM)Ruan Wrote: It's really a myth that an engine needs backpressure to make *power*... It needs the least amount of backpressure to make it's *PEAK* power - wherever that is in the RPM band, but as always with engines, it's a compromise, you want the backpressure there to prevent the valve overlap from sending half the mixture out the exhaust at low RPMs to keep up the midrange torque, but unrestrictive enough at high RPMs to allow the valve overlap to keep gas velocity up to let inertia keep pulling the gasses out the cylinders after TDC combined with the pulse tuning of the exhaust.
But that was probably more a problem on carb or manifold injection petrol engines than direct injection diesels which inject fuel when the valves are shut any way.
I would hazard a guess that a car would make more torque all over the place, and boost sooner, with no exhaust, vs with an exhaust fitted.
If there are gains had from removing back pressure, and then at a certain point ADDING restriction makes you gain power again, I'd be rather surprised!
Dave
