Threads: 128
21
Given 41 thank(s) in 38 post(s)
24-10-2016, 09:33 PM
(This post was last modified: 24-10-2016, 09:33 PM by toseland.)
(24-10-2016, 07:06 PM)Mattcheese31 Wrote: Roll it on logs, also if people could only lift 50kg they'd be total pussies
Worked for the egyptions.. they did have a couple of hundred thousand slaves tho and i dont think they were moving something quite this heavy
/Toseland
Nah i'm sure the 30-foot capstone was a breeze to lug about compared to cummins...
Rollers will work just fine, if you're really struggling for helpers use a couple of chocks while you move rollers and a ratchet strap to tow it.
Threads: 141
35
*awaits broken foot/ankle /leg pictures
Isnt there a tree just up from where you need it?
So a manual chain winch, couple pulleys to dial it down, and a couple 3' scaffold bars...moved in no time
Threads: 42
28
(25-10-2016, 08:36 PM)Piggy Wrote: Isnt there a tree just up from where you need it?
but he doesn't want to move the tree...
Threads: 541
124
The one nearest I chopped down, the other one isn't mine to uproot and is a bit far
Threads: 120
35
I have moved countless engines with the trailer method, thats your best bet i would say
Just put plenty of boards on the trailer to help spread the weight.
Team Cyril
Threads: 374
38
Car Model/Spec: GTI 6
TLDR.
Drop it on a wooden crate, get a tow rope or similar, tie it on numerous points of the crate and drag the fucker with the ranger
81
(26-10-2016, 07:39 AM)ginge191 Wrote: TLDR.
ffs mcstephenmcdetailface hes already said he couldnt do that.
Threads: 374
38
26-10-2016, 09:08 AM
(This post was last modified: 26-10-2016, 09:11 AM by ginge191.)
(26-10-2016, 07:55 AM)Eeyore Wrote: (26-10-2016, 07:39 AM)ginge191 Wrote: TLDR.
ffs samboatymcboatface, TLDR.
i MIGHT go back and read and see why this isn't an option - i managed to drag my engine (albeit by hand) across a muddy horse yard, let alone a smooth concrete driveway
EDIT: Read it, and he's deciding to use a trailer to lift it onto, how would the truck not get in but a trailer would. Think I need a picture to see what's up with this...
Threads: 145
sky hooks..... but seriously, do like the romans would, capture 100 slaves and use them.......no but seriously, pallet or similar, rollers and a ground anchor for the winch, like the tree........less messy than greased boards.
had a similar problem with a caravan, up hill on grassy road so car etc was out, used scotches and woman power, walked it up, bit by bit.
Threads: 90
Gotta ask the question though...if your having this much trouble simply moving the engine from point A to point B....how are you planning on dropping it in the truck??
Threads: 120
35
Other solution.. Hire a forklift
Team Cyril
Threads: 19
(26-10-2016, 03:16 PM)Matt-Rallye Wrote: Other solution.. Hire a forklift
on that note, what about a pallet and a set of these
Threads: 101
Car Model/Spec: 306HDi 90 LX
It goes, it stops (as reqd).
Hate Housework!
Threads: 47
14
Given 20 thank(s) in 20 post(s)
You forget I live down the road and am 6'10" and 16 stone of pure steroid pumped muscle.
I Don't Have A 306.
Threads: 541
124
(26-10-2016, 11:25 AM)darrenjlobb Wrote: Gotta ask the question though...if your having this much trouble simply moving the engine from point A to point B....how are you planning on dropping it in the truck??
Yeah, I've been pondering that issue. I think that I might just end up backing the crane against the kerb so it isn't going anywhere and then moving the truck rather than moving the engine.
