Leaky diesel return line
The diesel return line seems to be leaking quite alot. And it smells inside the car. The end seems to be opening. I should probably just change the hose. But it's minus 20 outside atm.. Tongue
Can I plastic zip tie it? Or will the heat of the area just melt it?
If I go about changing it. Any tips on how to remove it without filling the engine bay with diesel?
[Image: 20160122_200833_zpsrddmj4uw.jpg]
zoom back a bit its hard to work out where it is?
GTI6 Info
Not my engine bay, but its in this area
[Image: engine_bay_detail_zpsbryv5zk3.jpg]
Doesnt look like the smaller hose goes very far into the other one. Stops before the clampthingy. And since the other one seems to be pealing back a bit, its not weird that it leaks.
It's next to the cambelt cover behind the engine lifting point.
Edit - Too late haha.
Thanks given by: Iaitoo
Thanks anyways Tom, for helping locating the area Smile
Lol, no problem. I don't really have any advice though!
The engine heat wont melt zip ties but I'm not sure that would work anyway.
You can't really change it without spilling some diesel, it won't be loads as long as you're not pumping the primer lol. Just put some rag underneath to catch it.
Expecting warmer weather in a few days. Maybe I'll just go ahead and change it. Is the inner diameter 10mm on these? Bigger? As it goes over the other one Tongue
  Oil Return Leaking pugtk 4 1,390 10-02-2015, 08:30 PM
Last Post: pugtk
Question Leaky thermostat - which one to replace? akiller 6 2,008 30-11-2014, 11:55 AM
Last Post: akiller
  Oil return td_dan 1 984 02-05-2014, 03:01 PM
Last Post: silverzx
