Expansion tank!!! Help help!
#61
thermostst failed closed, water pump impellor ( no circulation ) cold patches on rad core, air lock........ blocked exhaust ( very poor performance )_ head gasket........try with thermostste out ans see how it gets on...........use a small tank to catch expanded overflow....will post pic next time in on here.....racing clock today!
Hopefully you've not cooked it
I hope not too!
(29-08-2015, 10:34 AM)pug306driver Wrote: thermostst failed closed, water pump impellor ( no circulation ) cold patches on rad core, air lock........ blocked exhaust ( very poor performance )_ head gasket........try with thermostste out ans see how it gets on...........use a small tank to catch expanded overflow....will post pic next time in on here.....racing clock today!
Mate i have taken thermostat out and now it seems to be worse?
I park mine on a hill and it flashes to say it's low on oil, park on a level surface and it's reading max
Have you tried flushing it out with a running hose. Fill it back up with water with a dye in it then as the water gets pumped round the engine as you bleed it. You can rule out a fooked water pump.
Have you tried any of the other suggestions?
I haven't had chance other than to put new bottle and cap and remove
Thermostat... This weekend I'm gonna spend all day on it and start eliminating all other possibilities
Any joy on this?
  Expansion tank overflow/rad cap pug306driver 1 919 15-05-2015, 09:52 PM
Last Post: Poodle
  expansion tank seams to be leaking tuttyboy84 3 985 30-04-2014, 08:18 AM
Last Post: tuttyboy84
