Expansion tank!!! Help help!
#61
thermostst failed closed, water pump impellor ( no circulation ) cold patches on rad core, air lock........ blocked exhaust ( very poor performance )_ head gasket........try with thermostste out ans see how it gets on...........use a small tank to catch expanded overflow....will post pic next time in on here.....racing clock today!
#62
Hopefully you've not cooked it
#63
I hope not too!
#64
(29-08-2015, 10:34 AM)pug306driver Wrote: thermostst failed closed, water pump impellor ( no circulation ) cold patches on rad core, air lock........ blocked exhaust ( very poor performance )_ head gasket........try with thermostste out ans see how it gets on...........use a small tank to catch expanded overflow....will post pic next time in on here.....racing clock today!
Mate i have taken thermostat out and now it seems to be worse?
#65
I park mine on a hill and it flashes to say it's low on oil, park on a level surface and it's reading max
#66
Have you tried flushing it out with a running hose. Fill it back up with water with a dye in it then as the water gets pumped round the engine as you bleed it. You can rule out a fooked water pump.
#67
Have you tried any of the other suggestions?
I haven't had chance other than to put new bottle and cap and remove
Thermostat... This weekend I'm gonna spend all day on it and start eliminating all other possibilities
#69
Any joy on this?
  Expansion tank overflow/rad cap pug306driver 1 2,162 15-05-2015, 09:52 PM
Last Post: Poodle
  expansion tank seams to be leaking tuttyboy84 3 2,555 30-04-2014, 08:18 AM
Last Post: tuttyboy84
Users browsing this thread: 33 Guest(s)
