02-03-2015, 05:59 PM
Hi gents,
So sadly I never managed to get to a conclusion on the gti6 forum so I thought i'd try the collective genius on here to see if anyone can help...
Ever since i bought the car (almost a year now) i've had no low speed fans, at all....ever...that goes for both fans, AND high speed the drives side fan only comes on...
So i've replaced:
1) All relays
2) One fan motor (both are fine)
3) Bitron
I've checked the continuity of the wiring around the relays which seem ok, AND if i bridge (now this was a while ago) but i think it was pins 3 &5 of the one relay both fans do spin up at low speed (so they both do work....)
Its a track car and does get hot, so i've done the AC button mod and just run the one fan (a al Rallye) at high speed which works, but its a bit cack if sitting in the pits etc, she gets hot very quickly on idle, with no low speed fan ever coming on.
I'm at a total loss, any ideas/suggestions? - the only thing i havent done is the earth under the battery as its a pig to get to and not sure how both can spin up at low speed when bridged AND one at high speed if the earth was dodgy....
Cheers
Chris
So i've replaced:
1) All relays
3) Bitron
Cheers
Chris
