Headlight Issue-B*stard Electrics at it again...
Headlights have decided to stop working, think ive narrowed it down to the switch.. So.indicators and horn work but side lights, dipped and full beam arnt working, have run a flying wire on.the back of the multiplug and can.get things workin...sort of. Just wondering is this going to.be.the switch or something.else?
Thanks, Adam Smile
Wack a stalk in for the sake of messing about and a tenner for a stalk!Smile
Probably broken wiring from being too low.
Replaced the switch and no joy..... tracked the wiring and there is a connector that is designed to short 2 wires together in the loom, wacked it off cleaned it and resealed it and works fine now. Apparently they are called Mick Jagger Clips, anyone heard of these before? Smile
(28-01-2015, 08:21 AM)welshpug Wrote: Probably broken wiring from being too low.
No that would be eith sump, lower control arms, handbrake cables or if your unluck fuel tank... hahaha Wink
I'm guessing they are some guys slang for IDCs?
https://www.google.co.uk/search?q=insula...s&tbm=isch
Thanks given by: Pug0BZ3011
ieth is welsh for..........yours  ish......dwyn meddwl?
joined wires in the loom, omg, where abouts please, just in case others and me get the same problem......please.
(03-02-2015, 10:42 AM)pug306driver Wrote: ieth is welsh for..........yours  ish......dwyn meddwl?
When you look at the headlight swich there are 2 connectors that go into the back of it. The one on the left hand side and two larger wires comming out of it, these have a blue icd on them to connect the circut, they had become corroded and needed cleaned.
Thanks given by: pug306driver
thanks for that....I clicked on the blue address 2 threads above and saw all sorts of stuff I have never seen before......so a sort of Peugeot scotchlock then?
thanks for the heads up.
diolch.
(04-02-2015, 11:56 AM)pug306driver Wrote: thanks for that....I clicked on the blue address 2 threads above and saw all sorts of stuff I have never seen before......so a sort of Peugeot scotchlock then?
diolch.
Basically clips over 2 wires then you cruse the probe in, this cuts the insulation and joins the wires.
oh, you have scotchblocks on your wiring, I'd look into why the hell they're there as they shouldn't be!
(04-02-2015, 12:21 PM)welshpug Wrote: oh, you have scotchblocks on your wiring, I'd look into why the hell they're there as they shouldn't be!
Going by the 'if its not broken dont try to fix it' plus MOT is in 2 weeks so have other things to get done. Plus I'm sure a lot of people are farmilar with 'felt spec' on here, all i can say it isnt MOT friendly!
This - whenever I see these anywhere near a car you know the electrics are going to be well and truly bodged...
Alarm installers are the worse culprits, but by no means the only ones.
  Damaged electrics, possibly relay?? windrushelectrical 0 224 08-07-2019, 10:05 PM
Last Post: windrushelectrical
  last "whats this for" on electrics pug306driver 3 562 18-02-2016, 09:30 PM
Last Post: pug306driver
  Test Rig for Tow Bar Electrics insomaniac45 24 1,603 07-12-2015, 07:23 AM
Last Post: THE_Liam
