Threads: 266
18
Car Model/Spec: 205 DTurbo
Given 7 thank(s) in 7 post(s)
What type of soldering wire? Tin/lead ok?
Flux paste as well?
Will a 60W electric soldering iron be up to the job or is gas / blow torch required?
Cable thickness is 25mm² and 75mm².
Threads: 541
124
You'll never get them sufficiently hot enough to do a decent job of soldering them without melting about 8 inches of insulation off the cable in either direction in the process.
Why not just weld them together?
Threads: 127
33
Car Model/Spec: ZX Volcane TD
plumbing solder and a blowtorch
Threads: 42
28
crimp and adhesive lined heatshrink, or a longer cable.
Threads: 541
124
What are you using it for 75mm2 is about an inch thick. There is no way you are going to get a decent solder of that.
Threads: 11
Car Model/Spec: 306 GTI-6 trackday toy
Crimp lugs on either cable and bolt them together instead, you'd need a gas torch to solder them otherwise, which will ruin a good portion of the insulation as Dum-Dum wrote above.
Also, a soldered joint is prone to cracking because of the vibrations in any vehicle.
Tinkerer of 306gti6 trackday racer, less stuff, more hard, more umpf, more stop.
To give you an idea, 75mm sq is about what is used on a 3P supply to a small factory!
Threads: 55
17
Car Model/Spec: 406 V6
Just get someone with the right tools to crimp them.
And wtf is one 70mm^2 when the other is only 25?!
Threads: 25
Car Model/Spec: Vectra & Berlingo
Given 5 thank(s) in 5 post(s)
100amp joint box for mains tails will tale 25 mm. They are about £10 from an electrical wholesaler. But 75 mm? That's about the size of CD.
Threads: 266
18
Lol @ some of these responses!
25mm² is what is fitted to my Datsun relocating the battery to the boot currently. I've just crushed the wires into the crimps as a semi-permanent job and they need soldering.
The 75mm² is what's on order for the 306's relocation jobby. I've got the crimps in front of me, it'll be fine. That's rated to 500A.
Threads: 58
as said plenty of flux and a blowtorch and feed both ends with a good amount of solder then join togther, ive soldered my earth wire on my mig in this fashion.
