Winch for 4x4
Winch for 4x4
http://www.ebay.co.uk/itm/ELECTRIC-WINCH...c#shpCntId
Looking for a winch for my 4x4 any one got any thoughts or recommend anything?
I'd prefer one with a steel cable tbh
Team Doesn't own a 306
After being at billing land rover festival and being in a 1hr winching seminar....steel cable is not a good idea.
Proper synth cable is stronger and safer. Also dont get a roller guide as they pinch. And make sure you get a compatible bumper to suit it.
Make sure the cables are also long enough to go direct to battery, inc the earth.
That one you have linked to seems to have all the right stuff...but 13000lb is WAY over the top.
Thats 13000lb vertical lift....you'll never need that. Plus it will be very slow. Between 7/8k lb will be plenty unless you're pulling trucks vertically up a cliff?!
Also worth getting a block and tackle Smile also dont see a tree strap/wrap in that kit which is a mega must for winching!
http://www.ebay.co.uk/itm/Warrior-S9500-...f#shpCntId
♦ Line Pull - No Load: 19.8 m/min (80 Amps)
♦ Line Pull - Full Load: 1.9 m/min (530 Amps)
What about that, looks to be fast
Iv already got snatch blocks and tree straps, only other thing i think i dont have is a ground anchor
you can never have a way over the top winch buy the bigest one you can aford the bigger it is the more under worked it will be
lasting longer (sure you know that though)
Not bad. Its a balance. You also dont want it to be too fast, you'll cause yaself injury if it goes wrong!!
unless its fitted to a sj it will never be to fast i don't
[img][Image: 20140730_205619_zps479f96b6.jpg][/img]
[img][Image: 20140730_205610_zpsd6aca801.jpg][/img]
[img][Image: 20140730_211908_zps323d2cd8.jpg][/img]
[img][Image: 20140730_205830_zps81e38f34.jpg][/img]
you wont winch that to fast if you get stuck lol i'd go for biggest one i could afford Smile
oh and thats far to clean
[Image: 7694_582880268443795_404823978_n.jpg?oh=...e=545A172E]
Needs 400mm drop and 'clones. Wink
(02-08-2014, 11:07 PM)Danny2009 Wrote: I'd prefer one with a steel cable tbh
unfortunately, steel is nasty.. dangerous and not worth it..
Warn, winchmax, are both good..
16000lb is overkill but itll winch faster under higher loads, both are good
i personally would go with warn, better solonoids.. but they cost more.. Plasma rope is the best you can get.. there are others available but thats the best
with winches more money is definately more quality.. although from that sort of price you are simply looking at faster
DEFINATELY DEFINATELY DEFINATELY get yourself a synthetic cable, much safer
/Toseland
