03-04-2012, 08:57 AM
mark_airey Wrote:Clearly straight into the turbo looking at the angle of it Dan, and what banjo fitting?
Actually, thinking about it, is the T25 not the same size oil inlet as the T2?
because why not just move the adaptor from the T2/K14 and just use the steel line??
Thats if its a T25 that your fitting? I don't think you have actually said!
You cant see what angle the center cartridge is at so it could be a banjo fitting. And Jakes is a TD04L, the standard oil in line had a banjo bolt/fitting.
