Indicator Issue
Indicator Issue
Every time I say this it sounds like a joke, but I have an intermittent fault with my indicators. They just stop working whenever they fancy it, and appear now to have completely died.
They don't do any clicking, so am I to assume the relay is the likely culprit, or is it more likely to be the stalk, or something?
Cheers
[Image: sigcopy-1.jpg]
Check the hazard light switch is plugged in properly.
I had this, faulty relay. Lots of intermittent life followed by complete death.
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
Pull the relay and take the case off, be pretty obvious if its worn.
Stalks can do this too mind. Both cheap and easy enough to replace mind
I'll check the connection on the hazard switch first, then the relay I guess.
Cheers chaps!
  Indicator / Hazzard Issue rocker8742 5 1,390 30-03-2014, 09:16 AM
Last Post: rocker8742
  Odd indicator issue Control_67 8 2,405 09-03-2014, 12:05 AM
Last Post: Control_67
  CORSA- indicator issue Kimmie 30 5,533 17-02-2012, 07:57 PM
Last Post: Niall
