EGT gauge
Wanted: EGT gauge
Anyone got one thats coming to pugfest that knows it works?
Got a decent sensor in...before I buy a decent gauge I want to check it works as a cheap crapinese version didnt!
Anyone?
how does your sensor connect?
Thermocouple type
(Standard thing we all normally use Smile )
Got a stack one, thermocouple and all....
JP
JP
(02-07-2014, 07:12 PM)Piggy Wrote: Thermocouple type
Well a stack differs from an autogauge for example in terms of how it physically connects on the gauge yeah?
(02-07-2014, 07:45 PM)jammapic Wrote: Got a stack one, thermocouple and all....
JP
^Buy this
Cheers tom. As you know, stack is not cheap shit...
JP
I know...but I aint got that sorta cash for that quality at this point...just need one I know works to try the sensor
Like I say, I've got a stack gauge and the stack thermocouple that came with it, all working perfectly and known good...
JP
I know JP...Im just not that flush at the moment, hence why I havnt PM'd you from your parts thread. As much as I would really like it
you can check a thermocouple works with a multimeter mate.. some multimeters have an EGT guage plug on, mine has an EGT setting for use with the standard probes in DC
/Toseland
What range on the multimeter?! Undecided
Anyone got one to bring to pugfest? Smile
A bump on this. Sensor good. Need a gauge, anyone got a cheapo one kicking about to sell? Smile
Still got a stack one...
JP
Still could only offer less than you want Tongue
£100, its cheap at that.
JP
Sure is. But its still twice what I wana pay. Esp as I am likely to only use it on a temp' basis!
I have a hks one, but I can't remember if it was the gauge or thermocouple which broke..
I need a thermocouple too now as mine is destroyed it turns out!
So may well get a new cheapo
Piggy, I have everything here... Wink
JP
I have a probe that looks a bit mangled but is a Stack branded one you can have for a £5'er if that helps. The adapter it's joint to cost me more than that alone.
Silver...already got a welded in threaded adapter in the manifold...would it fit that?!
JP...£50?
(03-11-2014, 10:01 AM)Piggy Wrote: Silver...already got a welded in threaded adapter in the manifold...would it fit that?!
JP...£50?
Meh dunno, I might of glued it in there or something, I'll have a look if I don't forget. Big Grin
(03-11-2014, 07:21 AM)darrenjlobb Wrote: I have a hks one, but I can't remember if it was the gauge or thermocouple which broke..
Can you check buddy?? Smile
ebay. 35quid. Sensor and gauge. mcmillen motorsport or something like that.
Works fine.
Just search EGT gauge.
Anything that will read a K-type thermocouple will do!
http://www.ebay.co.uk/itm/Digital-DC-Tem...3a905f693a
^^ Insanely cheap
http://www.ebay.co.uk/itm/4-Digitals-Tem...1c2c08d1f2
^^ Pretty cheap and has options for an alarm temperature etc.
That second one basically does two temp readings?? So I could have an intake air temp and exhaust temp?!
I had one of those cheap LED things...didnt work at all!
Nah, I think it has a little PID controller in it too - idea being for controlling a hot water tank and heater or similar... But will do the trick for you at a guess.
anyone got a k type thermo' I can buy to test this LED screen I already have??
