Threads: 591
54
Anyone got one thats coming to pugfest that knows it works?
Got a decent sensor in...before I buy a decent gauge I want to check it works as a cheap crapinese version didnt!
Threads: 591
54
Threads: 127
33
Car Model/Spec: ZX Volcane TD
how does your sensor connect?
Threads: 591
54
02-07-2014, 07:12 PM
(This post was last modified: 02-07-2014, 07:13 PM by Piggy.)
Thermocouple type
(Standard thing we all normally use  )
Threads: 106
7
Car Model/Spec: GTi-6
Got a stack one, thermocouple and all....
JP
JP
Threads: 127
33
(02-07-2014, 07:12 PM)Piggy Wrote: Thermocouple type
Well a stack differs from an autogauge for example in terms of how it physically connects on the gauge yeah?
(02-07-2014, 07:45 PM)jammapic Wrote: Got a stack one, thermocouple and all....
JP
^Buy this
Threads: 106
7
Cheers tom. As you know, stack is not cheap shit...
JP
Threads: 591
54
I know...but I aint got that sorta cash for that quality at this point...just need one I know works to try the sensor
Threads: 106
7
Like I say, I've got a stack gauge and the stack thermocouple that came with it, all working perfectly and known good...
JP
Threads: 591
54
I know JP...Im just not that flush at the moment, hence why I havnt PM'd you from your parts thread. As much as I would really like it
Threads: 128
21
Car Model/Spec: Stage3 HDi RHF5@25psi 174bhp
Given 41 thank(s) in 38 post(s)
03-07-2014, 08:35 AM
(This post was last modified: 03-07-2014, 08:41 AM by toseland.)
you can check a thermocouple works with a multimeter mate.. some multimeters have an EGT guage plug on, mine has an EGT setting for use with the standard probes in DC
/Toseland
Threads: 591
54
What range on the multimeter?!
Threads: 591
54
Anyone got one to bring to pugfest?
Threads: 591
54
A bump on this. Sensor good. Need a gauge, anyone got a cheapo one kicking about to sell?
Threads: 106
7
Still got a stack one...
JP
Threads: 591
54
Still could only offer less than you want
Threads: 106
7
£100, its cheap at that.
JP
Threads: 591
54
Sure is. But its still twice what I wana pay. Esp as I am likely to only use it on a temp' basis!
Threads: 90
54
I have a hks one, but I can't remember if it was the gauge or thermocouple which broke..
Threads: 591
54
I need a thermocouple too now as mine is destroyed it turns out!
So may well get a new cheapo
Threads: 106
7
Piggy, I have everything here...
JP
Threads: 266
18
Car Model/Spec: 205 DTurbo
Given 7 thank(s) in 7 post(s)
I have a probe that looks a bit mangled but is a Stack branded one you can have for a £5'er if that helps. The adapter it's joint to cost me more than that alone.
Threads: 591
54
Silver...already got a welded in threaded adapter in the manifold...would it fit that?!
JP...£50?
Threads: 266
18
(03-11-2014, 10:01 AM)Piggy Wrote: Silver...already got a welded in threaded adapter in the manifold...would it fit that?!
JP...£50?
Meh dunno, I might of glued it in there or something, I'll have a look if I don't forget.
Threads: 591
54
(03-11-2014, 07:21 AM)darrenjlobb Wrote: I have a hks one, but I can't remember if it was the gauge or thermocouple which broke..
Can you check buddy??
Threads: 41
3
Car Model/Spec: 306xrdt ph1
Given 4 thank(s) in 4 post(s)
ebay. 35quid. Sensor and gauge. mcmillen motorsport or something like that.
Works fine.
Just search EGT gauge.
Threads: 91
83
Anything that will read a K-type thermocouple will do!
http://www.ebay.co.uk/itm/Digital-DC-Tem...3a905f693a
^^ Insanely cheap
http://www.ebay.co.uk/itm/4-Digitals-Tem...1c2c08d1f2
^^ Pretty cheap and has options for an alarm temperature etc.
Threads: 591
54
That second one basically does two temp readings?? So I could have an intake air temp and exhaust temp?!
I had one of those cheap LED things...didnt work at all!
Threads: 91
83
Nah, I think it has a little PID controller in it too - idea being for controlling a hot water tank and heater or similar... But will do the trick for you at a guess.
Threads: 591
54
anyone got a k type thermo' I can buy to test this LED screen I already have??
