21-05-2014, 05:13 PM
What all do i need to do to change from k03 to k14?
Kkk003 can i change to k14 easy
21-05-2014, 05:33 PM
a k14 on it's manifold with it's high pressure oil feed, oh and a new manifold gasket.
21-05-2014, 05:35 PM
in fact i'll have one for sale in about a week, going td04
21-05-2014, 06:01 PM
Where did you get the adaptor plates mate? (do they do K03 to TD04?)
/Toseland
21-05-2014, 09:54 PM
One i seen has manafold and all pipes will it deff fit and are they good tirbos
21-05-2014, 09:57 PM
To be honest the t2 is the best of the standard turbos, kkk turbos don't seem to hold up with as much boost or abuse as t2s my t2 had 26 ish psi for about 3 years and was fine lol
What would the 14 be like ?
21-05-2014, 10:56 PM
(21-05-2014, 09:54 PM)pbell283 Wrote: One i seen has manafold and all pipes will it deff fit and are they good tirbos i've been running my k14 at about 22-24 psi for about last 3 years and it's fine, read my sig below for power results, pretty good i think, T2 isn't much different in my opinion and i've had both . . .
21-05-2014, 10:57 PM
(21-05-2014, 06:01 PM)toseland Wrote: Where did you get the adaptor plates mate? (do they do K03 to TD04?) you can get adaptor plates but i bought this already fabbed up on a manifold . .
22-05-2014, 09:18 AM
Soo 100 precent it will fit straight on if u buy the k14? As mines a 003
22-05-2014, 09:20 AM
(22-05-2014, 09:18 AM)pbell283 Wrote: Soo 100 precent it will fit straight on if u buy the k14? As mines a 003 it needs it's own manifold as the ko3 is different, but yes of course it will fit, it's a standard turbo..
22-05-2014, 09:22 AM
(22-05-2014, 09:18 AM)sweeney1987 Wrote:(21-05-2014, 10:57 PM)Mattcheese31 Wrote:Pics ot gtfo(21-05-2014, 06:01 PM)toseland Wrote: Where did you get the adaptor plates mate? (do they do K03 to TD04?) pics of what me auld paddy pal? x
22-05-2014, 09:43 AM
It comes on a standard manfold or do i need to make one for it ?
22-05-2014, 09:48 AM
(22-05-2014, 09:43 AM)pbell283 Wrote: It comes on a standard manfold or do i need to make one for it ? sorry what?
22-05-2014, 09:49 AM
The k14 im getting is on a manafold will it fit ?
22-05-2014, 09:51 AM
(22-05-2014, 09:49 AM)pbell283 Wrote: The k14 im getting is on a manafold will it fit ? how many times you want me to say yes? ...... Yes yes yes yes fcuking hell yes ffs lol
22-05-2014, 09:52 AM
Ha ok just making sure what can a k14 handle ? And is it bigger than a k03
22-05-2014, 10:01 AM
(22-05-2014, 09:52 AM)pbell283 Wrote: Ha ok just making sure what can a k14 handle ? And is it bigger than a k03 yes it is bigger, as for what can it handle, i wouldn't like to push mine much further than the 24psi it's been running although Ruan had one at about 30psi for quite a while
22-05-2014, 10:02 AM
Will all my pipes all fit still ?
22-05-2014, 10:04 AM
(22-05-2014, 10:02 AM)pbell283 Wrote: Will all my pipes all fit still ? fcuking hell mate are you winding me up? I told you what you needed in like the second post didn't i?
22-05-2014, 10:05 AM
True ha sorry lol gasket wont be that dear and is it the exhaut gasket i need ?
22-05-2014, 10:06 AM
As Matt says you need the complete turbo with all manifolds ect and the high pressure oil feed rest will fit, air filter piping boost pipes ect
22-05-2014, 10:11 AM
(22-05-2014, 10:06 AM)Danny2009 Wrote: As Matt says you need the complete turbo with all manifolds ect and the high pressure oil feed rest will fit, air filter piping boost pipes ect thanks Danny i'm losing my mind here
22-05-2014, 10:40 AM
Cant get any gaskets for 3 days what else could i use ?
22-05-2014, 10:52 AM
duck tape, WD40 and blu tac? might leak a little.. possibly catch fire
/Toseland
22-05-2014, 11:39 AM
Soo a t2 is best ? Is it the same as the l14 what i need
22-05-2014, 11:47 AM
T2 and K14 are the older generation turbos off the XUDs
Both use the same manifold and oil feed. The GT15 and K03 are the newer generation and use a different manifold and oil feed. T2 and K14 are said to take more of a hammering than the GT15 & K03 People prefer the T2, due to the actuator design, the K14 has a built in one which can cause issues if seized. That said I ran 26psi on a K14 for 1500 miles and the turbo is still fine. Ruan ran around 30psi IIRC on a K14, it survived and pushed out 147bhp Whatever you get your hands on just stick a new metal Inlet/Exhaust manifold gasket and drash on.
22-05-2014, 11:49 AM
Thanks thats good help il stick to the k14
22-05-2014, 09:13 PM
I got a t2 but no oil feed pipe will mine still fit
Urgent help needed, belt tensioner aux. Easy | Spoonaltap | 4 | 1,961 |
15-03-2016, 03:03 AM Last Post: maxaret |
Hitting High EGT to easy? | JamesPT | 4 | 1,805 |
15-12-2014, 04:35 PM Last Post: Ruan |
Bosch pump, easy seals to replace whilst off the car??? | Mattcheese31 | 8 | 3,096 |
23-11-2014, 06:15 PM Last Post: Mattcheese31 |
