	Threads: 93
8 Location: On a soap box
 Car Model/Spec: Stock HDi Meridian & Mk2 MX-5
 Thanks: 0Given 1 thank(s) in 1 post(s)
		Alright guys, I'm guessing this might be a problem for a few of us since the changes to the MOT guidelines, so I thought I'd start a thread.
 So I, like many of you, have decatted my HDi. Unfortunately, unlike most, I didn't just butcher the cat, as I already had a stainless cat back, so I got a stainless decat front pipe.
 Now, the new mot regs require a visual check for a cat, which obviously I will fail, so what's the best way of dealing with this? Shall i:
 1. Make a dummy cat, with a pipe straight through the middle, and weld in place of a bit which i cut out of mine.
 2. Attach a dummy cat to the outside of my exhaust, by cutting it down the middle, and then welding it shut on the outside of the pipe where the cat used to be.
 3. Build some sort of front pipe I can take in and out for the MOT, by modifying my current system so it has a flange.
 4. Get a full, standard system on the cheap (or borrow one?) and swap it at Mot time.
 5. Other
 How are you guys planning on dealing with it? Pain in the arse, but somehow it's got to be done.
 Cheers fellas.
![[Image: sigcopy-1.jpg]](http://i570.photobucket.com/albums/ss147/KEZZIEBOY/Diablo%20HDi/sigcopy-1.jpg)
	Threads: 465
114 Location: Cullompton Devon
 Car Model/Spec: Vauxhall
     Thanks: 1Given 98 thank(s) in 92 post(s)
		i vote other!
slip the MOT tester a beer token
mines running empty CAT as i knocked the centre out
visualy its there
	Threads: 92
43 Location: Brizzle
 Car Model/Spec: Tracterrrrrrrrr
 Thanks: 2Given 2 thank(s) in 2 post(s)
		Either don't worry about it, or weld a "cat" around your current exhaust
306oc Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam22:57: SRowell - :wtf why didnt you try harder to make me come!
 ![[Image: connorsig.jpg]](http://www.306oc.co.uk/forum/images/uploads/connorsig.jpg)
	Threads: 79
17 Location: Stroud, Gloucestershire
 Car Model/Spec: Down and out HDi racestate
 Thanks: 0Given 0 thank(s) in 0 post(s)
		Cable tie a cover so it cant be seen on the day. Take it back off again straight after.
	Threads: 226
24 Location: Cornwall
 Car Model/Spec: A3 TDi
		Find a better mot station lol...
	Threads: 581
195 Location: Bournemouth
       Thanks: 36Given 82 thank(s) in 78 post(s)
		 (16-03-2014, 06:13 PM)Tom Wrote:  Find a friendly mot station and take a pack of beer
EFA
	Threads: 371
29 Location: suffolk
 Car Model/Spec: ford fiesta
   Thanks: 4Given 82 thank(s) in 82 post(s)
		Got told by vosa themselves the other day. As older cars go how did you know it was there as standard can the tester prove it? No has to pass.
On a break from 306oc for personal reasons. If anyone needs or wants me most of you have my number and or facebook messengerThanks for the good times guys n gals. I might be back. Who knows.
	Threads: 117
119 Location: Southampton
 Thanks: 13Given 106 thank(s) in 106 post(s)
		Exactly that. ^^^
 If you're that worried weld a shell around it. If the tester fails it it's because they're a lady garden, not because the mot guidelines say anything without a cat must fail - because they don't say that.
	Threads: 371
		Also 90% of testers won't mind as long as it passes emmisions. If your a diesel your laughing if your car's before 2008 due to a massive amount of smoke aloud .
	Threads: 93
		I've seen the exact notice, it clearly states that a cat must be present.
 I would just use a pikey tester, but I like the garage I use, as they're incredibly anal, and they spot the stuff that I wouldn't, so I can sort it myself before it becomes an issue.
	Threads: 92
		 (16-03-2014, 08:21 PM)Kezzieboy Wrote:  I've seen the exact notice, it clearly states that a cat must be present.
If fitted at time of manufacture, pre 94 dturbos didnt have filters fitted, they can't be expected to be retro fitted
	Threads: 79
		Considering its in the hdi section i would guess we arent talking about pre 94 cars so all will be expected to have a cat.
	Threads: 92
		No I was just pointing out that it says all cars must have cats
	Threads: 117
		Isn't this all in relation to dpf's anyway?
	Threads: 371
		16-03-2014, 09:37 PM
(This post was last modified: 16-03-2014, 09:37 PM by bashbarnard.)
		No cat as standard it states I can take PIC of special notice tomorrow and upload
 It states not as states
	Threads: 93
		Nope, cats too poodle.
 Either way, that's not the point not here, the fact is that it's now an MOT fail to have a decat on an HDi, so how best to avoid immediate failure?
	Threads: 68
4 Location: Holbeach, Lincolnshire
 Car Model/Spec: 306 HDI
		bloke i use for mots is pretty sound as long as it passes emissions he is okay.
 if you moter is anal, i would either put a cover over it or like i did kept my old exhaust with cat, in your case borrow or buy one for mot time
 suppose it depends how picky they are mate
	Threads: 47
1 Location: Cambridgeshire
 Car Model/Spec: 306 HDi
		ive mot'd my 306 hdi, on saturday and she passed, with just a mid to back box conversion, no cat, no back box
	Threads: 110
20 Location: Devon
 Car Model/Spec: Estate, DT, GTI6 and 205
       Thanks: 1Given 30 thank(s) in 30 post(s)
		At the end of the day to all down to the tester
	Threads: 45
0 Location: Ludlow, Shropshire
 Car Model/Spec: HDi DTurbo 2001(Y) Astor
		19-03-2014, 03:08 PM
(This post was last modified: 19-03-2014, 03:09 PM by Razorback_Rob.)
		I'm welding the cat casing off my original downpipe and cat onto my decat pipe. Should pass visuals and smoke test just fine
Team disASTOR?
	Threads: 93
		Only concern with that method is that the cat will be mild steel, whereas my exhaust is stainless, so it'll be introducing some nice corrosion into the system :/
	Threads: 117
		Get a stainless one made then lol.
	Threads: 93
		Can you get stainless cats? Wont they be a bit expensive to buy just to bash the insides out?
	Threads: 117
		So you're buying a real cat rather than having the box welded around the outside? Seems a bit retarded if you're just going to empty it anyway...?
	Threads: 92
		Kez find an exhaust place and ask them for a stainless "cat" /drevil
	Threads: 28
2 Location: Lost In Music between London and Kent
 Car Model/Spec: Phase 4 Silver HDi Estate
		from what i understand from my last test as long as the exhaust is not blowing and emissions are fine it passes. mine had a cat on it but i done a decat and tester said nowt except it's really good on emissions lol.
 guess does depend where you go
