Water coolant light
Water coolant light
After doing my clutch and gearbox I noticed a plug wasn't plugged in going into the coolant expansion tank, so I plugged it in and the light comes on, but it goes on and off whilst your driving. I drive home from work which is 15 minutes, it will go on for abit then it will suddenly go off.
Is your coolant level low?
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1994 Mercedes Benz 320E.
1997 306 GLX.
(04-03-2014, 07:32 PM)ADV_93 Wrote: Is your coolant level low?
No its on max
It's a faulty sensor, probably the reason it was unplugged lol! It's not uncommon on these. Smile
So will I have to replace the expansion tank or? Where is the sensor
Just replace the sensor. Its just a push and twist fit in the back (engine side) of the header tank. Or just unplug it again lol.
Try taking it out and clean the scale off the two prongs, then it should work fine.
With this light on an off, Ive got an MOT saturday and with my luck it will come on, will it fail the MOT?
Not if you unplug it.
No it wont, you might get an advisory.
  Coolant light flashes every so often aaron_one 5 1,223 14-10-2015, 09:13 AM
Last Post: pug306driver
  coolant light on UPDATE rd070707 55 8,515 18-09-2013, 07:52 PM
Last Post: Face.
