Threads: 6
Car Model/Spec: Peugeot 306 1.8
Wondered if anyone could help me with this.
Got the car out the garage yesterday and left it running to warm up, after about 5 minutes it started idling between 500 and 1000 revs jumping up and down trying to keep itself running eventually sorted itself out
today i went out drove about 5 miles come to a junction engaged the clutch and the car cut out started straight up again however keeps doing it.
any help?
Threads: 70
7
Car Model/Spec: Astor GTI6
Lambda, TPS?
What engine?
Idle valve.
Remove, clean, replace
Or fit a replacement
Threads: 6
is it easy to get to on these?
Threads: 122
9
Given 7 thank(s) in 7 post(s)
Yeah will be on/around the.throttle body
Yep ICV. Can clean them but generally it doesn't last long. Once they are shot, that it and unfortunately, the pattern ones are not much better. A Genuine one is about £80 but its honestly a false economy buying the cheaper copies as they won't last long at all!
Threads: 10
Car Model/Spec: Ph3 1.8 petrol
mines started doing this...only picked it up a few days ago, will have a look at cleaning icv tomorrow, thought it might have something to do with fitting my bmc.
Threads: 61
11
Icv I reckon. A friend of mine had a similar problem and it was actually the power steering sensor.
