Car Cutting Out - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: Car Cutting Out (/showthread.php?tid=19833) |
Car Cutting Out - Ashwoody - 23-12-2013 Wondered if anyone could help me with this. Got the car out the garage yesterday and left it running to warm up, after about 5 minutes it started idling between 500 and 1000 revs jumping up and down trying to keep itself running eventually sorted itself out today i went out drove about 5 miles come to a junction engaged the clutch and the car cut out started straight up again however keeps doing it. any help? RE: Car Cutting Out - Carlos182 - 23-12-2013 Lambda, TPS? What engine? RE: Car Cutting Out - Ashwoody - 23-12-2013 sorry its the 1.8 xs RE: Car Cutting Out - Piggy - 23-12-2013 Idle valve. Remove, clean, replace Or fit a replacement RE: Car Cutting Out - Ashwoody - 23-12-2013 is it easy to get to on these? RE: Car Cutting Out - Piggy - 23-12-2013 I believe so RE: Car Cutting Out - Ashwoody - 23-12-2013 cheers RE: Car Cutting Out - Jimbo - 23-12-2013 Yeah will be on/around the.throttle body RE: Car Cutting Out - Niall - 23-12-2013 Yep ICV. Can clean them but generally it doesn't last long. Once they are shot, that it and unfortunately, the pattern ones are not much better. A Genuine one is about £80 but its honestly a false economy buying the cheaper copies as they won't last long at all! RE: Car Cutting Out - Ashwoody - 23-12-2013 think ill just cope until february then back to a diesel i think
RE: Car Cutting Out - cluskie - 24-02-2014 mines started doing this...only picked it up a few days ago, will have a look at cleaning icv tomorrow, thought it might have something to do with fitting my bmc. RE: Car Cutting Out - 7057sam - 24-02-2014 Icv I reckon. A friend of mine had a similar problem and it was actually the power steering sensor. |
