30-12-2013, 03:02 PM
tim, just put up a wanted ad...bet theres loads stuck in boxes in sheds of loads of us here
dump valve leaking oil
30-12-2013, 03:06 PM
cheers kyle
30-12-2013, 03:08 PM
You dont need to get under one you can do it all from the top shouldn't be a big job at all max 30mins as it can be fiddly.
30-12-2013, 04:45 PM
Dump valve is off and a mate has capped the T pipe for me just need to buy a turbo for it now anyone no who's selling one cheap as poss
30-12-2013, 04:51 PM
(30-12-2013, 04:45 PM)DTurboTom Wrote: Dump valve is off and a mate has capped the T pipe for me just need to buy a turbo for it now anyone no who's selling one cheap as poss Might not need to buy new turbo if it's only a small amount of oil.
30-12-2013, 05:24 PM
yeah, may just be breather system, you be amazed how much oil and residue is inside all the pipework even on a perfectly good turbo.
Who knows how long that dumpboostvalve has been leaking like that. Is it dropping boost or whinning? Wishes for more power...
30-12-2013, 05:37 PM
not boost and yeah it winns lol
30-12-2013, 08:50 PM
I used a piece of pvc plumbing pipe to join back the tmic.
That may not be excessive depending how long it has been building up for. Either way remove the dv as yours will just be causing a major boost leak as the spring isn't strong enough to resist the boost pressure
30-12-2013, 10:08 PM
dump valves off mate just need a new turbo
30-12-2013, 11:41 PM
Will I need any fittings or will that just go straight on
Dump valve on a diesel? | 306pc | 14 | 2,634 |
29-07-2014, 04:34 PM Last Post: ADV_93 |
Oil leaking from EGR valve | HDIkyle | 0 | 820 |
29-01-2014, 02:25 PM Last Post: HDIkyle |
fitted a dump valve now lossing boost | ingham66 uk | 9 | 2,493 |
15-06-2013, 11:23 AM Last Post: Piggy |
