Threads: 119
Car Model/Spec: MG ZS180
22-12-2013, 10:05 PM
(This post was last modified: 22-12-2013, 10:12 PM by Ricky.)
Wondering if anyone has had this problem before. When driving along at night every now and then my headlights dip for a split second, its been doing it for a while but has recently got slightly worse. I've always suspected maybe bad earth somewhere or the fact that my battery terminals aren't as tight as I would like them. Within the last couple of days however I get an intermittent power loss, only for a split second but its enough to feel it, and I'm pretty sure my lights dip at the same time.
Anyone have any ideas/experience with a similar problem?
Are the battery terminals easily dislodged? If so, that's probably your culprit.
Threads: 119
It could probably get the negative terminal off without loosening the bolt yeah.
23-12-2013, 11:19 AM
(This post was last modified: 23-12-2013, 11:19 AM by Piggy.)
There ya go then
Just run along all the cables checkin each connection
Threads: 202
58
Hmm. May have to go check my battery, I'd put it down to puddles making the aux belt slip. But being lazy I hadn't yet tensioned it up
Threads: 119
I'm going to get new battery terminals because the negative won't go any tighter and the positive is a horrible quick release type.
Threads: 24
My hdi did this was due to a bad battery.. The car would normally start fine but in cold weather the battery would be flat and unable to start it
