GTi oil/water heat exchanger
Anyone got one they can send me?
Edit:
Also need a rallye aux belt setup in good condition, lower cam belt cover and gti6 throttle body bolts.
Edit again:
Also need a good XSi coil pack.
I've got several just need to find one
Also what belt cover do you need ?
Inner or outer?
There's 2 types of outer, one has a sliding bar which hooks over studs, the other is held is place with nuts.
Iv got a complete rallye setup mate, £40posted
Current cars
Subaru Impreza 2.0d - Daily
(21-12-2013, 04:06 PM)Paul_13 Wrote: I've got several just need to find one
Inner or outer?
I need the smallest cover that goes around the crank at the bottom. bolts to the block with 2 small bolts.
(21-12-2013, 04:08 PM)td_dan Wrote: Iv got a complete rallye setup mate, £40posted
Good condition? No rattles or odd noises or play in the pullies?
Iv never fitted it, i bought it as working with both tensioners, bolts and belt, just looked at the belt and theres cracking so id say 30posted would be better
Current cars
Can you just do me a favour when you get a chance and see if there is any play in the pullies and also spin them and see if they rattle? Cheers Smile
Should have the cover mate
Give me a couple of days to get the bits
they spin freely enough no noises or play although one is a tiny bit stiffer to spin but that maybe the fact theyve been in a box in the garage for 12months
Current cars
(21-12-2013, 04:46 PM)Paul_13 Wrote: Should have the cover mate
No rush mate. Can pick them up from you at Ace in Jan if your going?
(21-12-2013, 04:52 PM)td_dan Wrote: they spin freely enough no noises or play although one is a tiny bit stiffer to spin but that maybe the fact theyve been in a box in the garage for 12months
Ok mate PM me your details and ill send the cash over Smile
Sounds good to me mate, need the bolt that goes through the middle?
If you have one then yeah please Smile
  GTi6 oil Heat exchanger MCH 5 1,842 07-07-2015, 04:44 PM
Last Post: MCH
  Wanted: ASAP oil cooler/heat exchanger bolt Piggy 22 8,156 11-02-2014, 03:36 PM
Last Post: Frosty
  Wanted: Hdi Heat Exchanger Daniel306 3 988 31-12-2013, 05:28 PM
Last Post: JamesG
