anyone fancy a swim
anyone fancy a swim
foot well lol
Attached Files Thumbnail(s)
Oh f*ck! That is epic!!!!
You should get some garden ornaments and make that into a nice water feature.
[Image: sigjpg.jpg]
Serious.
Thats the worst one I've ever seen!
it a good the misses get wet every morning
Just drill a hole in the floor and all will be fine.
I've seen worse....
On cars I've been breaking for parts without doors though.... Confused
(14-11-2013, 12:03 AM)Toms306 Wrote: I've seen worse....
Thats what i was thinking hahaha the cars up the scrapyard have smaller puddles! Get a hose and someone to sit in the car, i imagine a leak like that will be pretty easy to find!
LOL!!! Clogged door seal i had this in my old dt if i parked it passenger sidw facing down hill . Replaced the seal in the end and it sorted it
Wow, that really is scrapyard spec lol
As Jamie said, door seal is your most likely culprit.
ok cheer will have a look later on
Haha standard, many a times have i got in my DT to find this.
Shotgun, i mean 2mm drill to the floor fixes it Wink
[Image: sigi-2.png]
i was thinking that i just smacked the drain bungs out. draining slowly
There seems to be an usual amount of these threads popping up recently..
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
(14-11-2013, 11:23 AM)silverzx Wrote: There seems to be an usual amount of these threads popping up recently..
Was just thinking this
306 with a pond, nice mod lol
Obviously we have more rain at this time of year but still..
The 306 fairy might be tampering with everyones cars?
S14 Zenki Build
(13-11-2013, 11:06 PM)daniel909 Wrote: it a good the misses get wet every morning
What you did there......
I see it.
On the 306 waiting list.
Tbh things like this will be more common the older the cars get. Also rust, even mine which is low mileage and phase 3 is showing signs of rust
(14-11-2013, 12:24 PM)Jonny81191 Wrote: Tbh things like this will be more common the older the cars get. Also rust, even mine which is low mileage and phase 3 is showing signs of rust
I think we can fairly safely blame DumDum for that though haha!
my rovers floor pans get worse than that, when the door seal acted up.
I wish I could, but the rear bump stops are starting to go (seems to be one of the first areas to develop issues) and there really is no way that's Chris' fault.
He's to blame for the rear arch though, there was a LOT of mud up the top there holding moisture just nicely Big Grin
I got in early but then my leak came back Sad
If it makes you guys feel better, my Mum's 12 plate car had a soggy floor mat and condensed water on the inside of the windscreen recently....
I've got an idea that the rubber seals dry out over the summer, which reduces their flexibility and then waterproofness....soon as they get wet a few times, get back into shape and it doesn't happen again until the same time next year.
Stab some holes in the outer edge of the seal at the lowest point, that fixed mine! It was on the drivers side as well, wasn't really bothered until the morning it froze.
Oh god thats bad! And i thought the bianca had a pond haha!
My dogs would love that. Mobile waterbowl. Lol
  I quite fancy one of these ROBCAT 2 1,207 04-08-2017, 08:22 AM
  Any one fancy swampy 2 989 02-05-2015, 08:24 PM
Last Post: Iceman299
  Anybody fancy fitting a 5th gear synchro? Iceman299 8 2,351 11-02-2015, 12:53 PM
