Threads: 26
Car Model/Spec: 306 D Turbo Phase 1
Just want to know if the gti6 engine and gearbox will fit in a mg zr? As might be selling engine to cousin for his track car comments appreciated thanks!
Black 306 1.9 dturbo PH1 - on going project
Moonstone 306 GTI6 PH2 - Stripped and Scrapped
Honda Civic EP3 preface lift type R - Write off/Stripped and scrapped
Diablo 306 1.9 dturbo PH3 - Scrapped
Honda Civic EP3 facelift type R - daily
Threads: 82
27
Anything would with enough time and money.. but it's not a straight fit..
Threads: 169
91
You would need new engine mounting points welding in, either adapting the chassis to fit a 306 subframe, or adjusting the existing drivetrain to fit the '6 lump.
Not an easy task however you look at it
Threads: 26
Ok thanks guys!
Threads: 61
Given 6 thank(s) in 5 post(s)
The driveshafts will need modifying, also on the mg the exhaust manifold is at the front of the engine so on a 6 engine you will probably have to cut a tunnel in the bulkhead to run the exhaust down the back
Threads: 169
91
Or get really clever, take the gearbox apart, reverse the internals and mount the engine 180 degrees around.
Failing that, retrofit the MG Box to the '6 engine. I have no idea what the engine bay of the MG looks like so I'm firing in the dark here! lol
Threads: 226
24
Car Model/Spec: A3 TDi
Way more work than it would be worth imo. Surely some kind of turbo'd rover lump would be alot easier?!
Threads: 169
91
Rover Turbo V8 did I hear?!
Threads: 226
24
V8 twin turbo anyone!
Remember that the MG ZR was designed for a super light ally block 1.8 weighing sub 100kg... A GTi6 is a iron block 2.0, canted back with hefty 6 speed gearbox.
TBF in terms of engine designs, you couldn't really get much different! The only real similarities are that the're both 4 cylinder 16vs....
Threads: 26
14-10-2013, 01:59 PM
(This post was last modified: 14-10-2013, 02:00 PM by BenDturbo1.)
Cheers everyone, loads of help! Think he's looking at 2.5 v6 engine now
*2.5 v6 zs engine
Threads: 169
91
Why? Just slap a rover v8 in it. I would have thought it would be an easier job?
Threads: 26
Or either that yes! Ill have a word with him tomorrow and see what he thinks to it, most likely he will want that! Haha :p
Threads: 226
24
V8 would be win. Friend of mine just put one in an old rx7!
Threads: 39
Car Model/Spec: P2 Dturbo
it's still a rover though
00' 106 Indy - Moonstone - Sold
97' 106 XT 1.6 - Mayerling Green - Swapped
95' 306 P1 DT - Onyx - Scrapped
97' 306 P2 DT - Silver - Scrapped
97' 306 P2 DT - Onyx - SORN awaiting scrap
Threads: 102
9
id just leave the vvc running gear in the posh 25
Threads: 29
Car Model/Spec: 306 2.0 8v Turbo
I would stay well away from the V6 K6 lump, it suffers like all other K series S**T with the god ol headgasket.
Maybe think about the Rover 2.0 Turbo engine that was fitted to the 200 Tomcat, there are a few on EBay
1999 2.0 8v Turbo 306
You Tube: 832 Performance
Threads: 102
9
v6 k6 lump is very expensive to fix let alone do a belt on one!
better off as mentioned T series the car or leave it be, as rover modifing is a bit of a f*ck on, trust me on that one.
Threads: 19
Car Model/Spec: Xantia HDi shed
(14-10-2013, 11:38 AM)BenDturbo1 Wrote: Just want to know if the gti6 engine and gearbox will fit in a mg zr? As might be selling engine to cousin for his track car comments appreciated thanks!
Your 'cousin' isn't lolsteve, is he?
This is his plan to 'beat a GTi-6' eh?
Threads: 10
Go for the T16 it's a far better swop that's what I got in my zr
Threads: 26
