25-09-2013, 09:26 PM
Hi guys does any one know if u can turbo or supercharge the 1.6 8v and if so where can I get the kit from many thanks
1.6 turbo/supercharger
25-09-2013, 09:28 PM
My advice would be to fit a 16v 1.6 TU engine then turbo it. They are bullet proof engines and good for over 300bhp on stock internals. On a 306 it will be easy as the exhaust manifold is at the front and there is plenty of room in the bay!
25-09-2013, 09:35 PM
Would it be possible to put a 16v head on my 8v and then turbo it ?
25-09-2013, 10:31 PM
You'd be better off doing a full swap iirc the pistons are different
26-09-2013, 05:43 AM
not only the pistons, but to fit the 16v timing belt you'd need to fit the extra idler pulley, but there isn't anywhere for it on the 8v block
do both imo, supercharger in front, turbo over the gearbox... http://www.gmcmotorsport.co.uk/
Project: Formula Peugeot
26-09-2013, 07:09 AM
as said above you'd be better off using the 16V iirc there are "kits" for it. but there is nothing for the 8v it would have to be a complete home bru
26-09-2013, 08:01 AM
The VTS/GTI engine can take huge amounts of boost, there's loads around on 300bhp+ on standard internals like the eater of crayons says but 200bhp shouldn't be right expensive I wouldn't have thought...
