1.6 turbo/supercharger - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: TU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=18) +--- Thread: 1.6 turbo/supercharger (/showthread.php?tid=17594) |
1.6 turbo/supercharger - Daveg306 - 25-09-2013 Hi guys does any one know if u can turbo or supercharge the 1.6 8v and if so where can I get the kit from many thanks RE: 1.6 turbo/supercharger - Niall - 25-09-2013 My advice would be to fit a 16v 1.6 TU engine then turbo it. They are bullet proof engines and good for over 300bhp on stock internals. On a 306 it will be easy as the exhaust manifold is at the front and there is plenty of room in the bay! RE: 1.6 turbo/supercharger - Daveg306 - 25-09-2013 Would it be possible to put a 16v head on my 8v and then turbo it ? RE: 1.6 turbo/supercharger - 306Dan - 25-09-2013 You'd be better off doing a full swap iirc the pistons are different RE: 1.6 turbo/supercharger - John1.4 - 26-09-2013 not only the pistons, but to fit the 16v timing belt you'd need to fit the extra idler pulley, but there isn't anywhere for it on the 8v block do both imo, supercharger in front, turbo over the gearbox... ![]() http://www.gmcmotorsport.co.uk/ RE: 1.6 turbo/supercharger - Piggy - 26-09-2013 you can turbo anything
RE: 1.6 turbo/supercharger - puglove - 26-09-2013 as said above you'd be better off using the 16V iirc there are "kits" for it. but there is nothing for the 8v it would have to be a complete home bru RE: 1.6 turbo/supercharger - Midnightclub - 26-09-2013 DP engineering do turbo kits for the 1.6 16v for about 1850 euro RE: 1.6 turbo/supercharger - THE_Liam - 26-09-2013 The VTS/GTI engine can take huge amounts of boost, there's loads around on 300bhp+ on standard internals like the eater of crayons says but 200bhp shouldn't be right expensive I wouldn't have thought... |
