31-08-2013, 10:01 AM
as title pretty much says, how dyu go abouts getin the back axle off?
How to remove rear axle? :)
31-08-2013, 10:07 AM
Literally 6 bolts in the boot.
Check YouTube for darrenlobb axle change
search darren j lobb in google and his webpage has a guide on it, lift the carpet, pop out rubber bung and undo basically
31-08-2013, 10:12 AM
remove exhaust back box and drop mid pipe.
remove spare wheel and hanger. jack and support rear remove wheels remove handbrake cables from underside/inside of car undo brake pipes undo clip abs x2 if it has it 6 bolts in boot and it will drop to floor. good idea to have jacks and mates holding it! reverse to refit. remember to bleed brakes! Wishes for more power...
As above...but remember to disconnect the brakes first lol. And wiring for ABS is applicable.
Edit - I'm too slow as usual!
31-08-2013, 06:20 PM
(31-08-2013, 10:12 AM)Piggy Wrote: Get 2 strapping young lads to come round and fit it for you. Well one of them young... and strapping. The othet just strapping on a dildo for his date later that evening EFA 306oc Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam
31-08-2013, 07:12 PM
(This post was last modified: 31-08-2013, 11:56 PM by devils_fuel.)
(31-08-2013, 10:13 AM)Toms306 Wrote: Edit - I'm too slow as usual! (31-08-2013, 06:20 PM)Connor Wrote:(31-08-2013, 10:12 AM)Piggy Wrote: Get 2 strapping young lads to come round and fit it for you. Well one of them young... and strapping. The othet just strapping on a dildo for his date later that evening Ha ha I know who those 2 are then from piggys description... the smokey old bus that sounds like a tractor...
31-08-2013, 11:13 PM
That's what they all say, it wasn't me lol.
03-09-2013, 09:46 AM
(31-08-2013, 10:12 AM)Piggy Wrote: remove handbrake cables from underside/inside of car When you have undone the handbrake cables inside the car can they be passed though the floor out the bottom of the car? I assume they can as it looks like one continuous cable from the caliper to the adjuster at the handbrake.
03-09-2013, 10:45 AM
yep. tug from underneath and they just pop out
03-09-2013, 11:16 AM
03-09-2013, 06:05 PM
(31-08-2013, 10:12 AM)Piggy Wrote: remove exhaust back box and drop mid pipe. I'm just wondering actually if it would be worth cracking the bolts loose but leaving the wheels on, that way when you undo it, the discs/drums won't hit the floor? (03-09-2013, 10:45 AM)Piggy Wrote: yep. tug from underneath and they just pop out *giggidy*
03-09-2013, 07:50 PM
as others can testify...unless you have the car about 2feet in the air, if you leave the wheels on, you cant get the beam out from under the car!
03-09-2013, 08:26 PM
(03-09-2013, 07:50 PM)Piggy Wrote: as others can testify...unless you have the car about 2feet in the air, if you leave the wheels on, you cant get the beam out from under the car! Fair point, can't argue with that
I seem to remember GTIKYLE removing a beam with the wheels still on...in the most pikey way possible balancing it on bricks!
06-09-2013, 01:17 PM
easiest way is to support the trailing arms with axle stands and drop a trolley jack down slowly in the middle of the beam..
did it this morning and vice versa for refitting it only took about 20 minutes
00' 106 Indy - Moonstone - Sold
97' 106 XT 1.6 - Mayerling Green - Swapped 95' 306 P1 DT - Onyx - Scrapped 97' 306 P2 DT - Silver - Scrapped 97' 306 P2 DT - Onyx - SORN awaiting scrap |
Rear stub axle sizes | weka | 2 | 2,125 |
26-04-2019, 06:18 PM Last Post: weka |
rear axle | joe67 | 4 | 2,716 |
25-04-2018, 08:38 PM Last Post: carlukepeugeot |
rear axle beam tube quality | dsm482 | 10 | 4,043 |
22-12-2017, 02:01 AM Last Post: dsm482 |
