Water Pump Which ???
Looking for a new water pump as getting bosch fitted but on ECP there is 4 diff types,
Any idea which mine is
N Reg 306 1.9TD XUD
From what I have read it is down to the cambelt cover but im stuck
There is a few listed in ECP but from what I can see
http://www.eurocarparts.com/ecp/c/Peugeo...97c&000366
or
http://www.eurocarparts.com/ecp/c/Peugeo...bc3&000366
HELP it says to check idler pulley or something but not sure
You need to find out which XUD you have, e.g. DHY
Or put your reg in and it might help, that link is just for a N reg 1.9.
Thats 2 of the ones that came up when I put my reg in ECP
I think there all the same across all of the Xu engines,
No they are not all the same, some are poorly made and wont last, I only get mine from Peugeot themselves, worth the extra it costs, its one thing you dont want wearing out premerturly.
I think there's 2 different types, both fit except one of them has a 'side' on the pump where your timing cover should be, the other hasn't so the timing cover fits straight on without having to cut it.
Just had a look at the engines i have here(Xud, Dw and Gti6) i have here and they all have got this cover part.
This is from when i asked the same question
http://306oc.co.uk/forum/thread-1079.htm...water+pump
  DW8 Timing belt cover / water pump bolt size? jamesgmg 13 4,727 06-07-2017, 03:41 PM
Last Post: Mighty306
  water pump help sb194114 4 1,114 25-03-2015, 10:28 AM
Last Post: cully
  water pump differences? ash23 1 980 11-06-2014, 05:20 PM
Last Post: ConorTRG
