Wires through the bulkhead?
I have tried searching but can't find anything, I know I've read it in a thread somewhere before but can't remember where, basically
What's the best way to route wires/vacuum pipes into the cab? I've read somewhere that the "ac bung" is the best place, but where is that? Cheers guys Smile
Blaze '6 and Blaze D-turbo!
Ac bungis at the top of the passenger footwell
Apparently there's also a good one for boost pipes by the master cylinder
Just drill through!! :p
Black mask Service
(04-07-2013, 09:59 AM)Rich306 Wrote: Just drill through!! :p
ask Puglove where not to drill! Undecided
If you have a rallye then going through the AC bung is going to be a bit pointless lol.
Does your D-tub have AC?
There's a hole just off to the right and down of the brake servo as you look at it from the front
Cant remember what goes through it
(04-07-2013, 12:36 PM)Grant Wrote: If you have a rallye then going through the AC bung is going to be a bit pointless lol.
Should of said that this was regarding the d tub, it did have ac but not anymore, managed to get them through that bung tonight, cheers guys Smile
Ah fair enough then mate.
Thats the steering column universal joint phil Smile
(04-07-2013, 01:28 PM)4WayDiablo Wrote: There's a hole just off to the right and down of the brake servo as you look at it from the front
(04-07-2013, 09:19 PM)Grant Wrote: Ah fair enough then mate.
I'm sure that does go through somewhere around d there
But its not that!
Ginge knows his boost gauge went through it. Maybe one of the pedal cables
Could be the clutch or accelerator cables then in that case. The UJ or the steering column is a nice big gromit though so nice and easy to do there Smile
To the right of the master cylinder is a lovely one. I got vacuum hose and amp power going through that one Smile
Ok cheers guys, sure they will all come in use Smile
  drivers door loom wires pug306driver 3 1,548 27-11-2016, 06:29 PM
Last Post: BiG K
Photo radio wires rosylyn 3 1,420 31-03-2015, 11:55 AM
Last Post: Toms306
  where do the wires for the sidelights run Hamish 0 963 09-06-2014, 07:20 PM
Last Post: Hamish
