Removing rear drum
Removing rear drum
Removed hub nut, circlip and washer! Been smashing the drum for an hour or so with hammers and chissels, seemed to move about 10mm on top and 5 botton barring in mind me and a m8 havr been hitting it around the whole drum.
Any ideas why the bastard isnt coming off?
Attached Files Thumbnail(s)
Frm wht I cld undrstnd v ur txt speakz innit! (just talk normally mate is easier for people to understand you, thus you may get a little more help)
You need to slacken off the shoe adjuster nut, as the shoes are holding the drum on as it is Smile
Handbrake on?
If you've got a spare wheel you don't need knocking around, put it on and batter the life out of it. I had to do the same when I changed my rear brakes. Just gives you some more leverage to get the drum off. Wink
Sorry grant was writing it in a hurry because it was raining and I had all my tools out Wink
Handbrake fully off and released the handbrake operating lever
get a crow bar in there, or a large flat head screwdriver. it will come, they do get f*cking seized, just keep ramming it, turning, ram, turn, ram, turn.. pop. giggedy.
slacken the handbrake---un-adjust it loads so the handbrake lever allows the shoes to retract.
then a big screwdriver in either side and wiggle it off.
The bearing could be stuck on the stub axle
Smash the stub axle through the centre
[Image: av5ym8.jpg]
I agree with Wingnutz.. The way I have always done it.
Dw just sorted it! Guy who lives opposite me is a citreon mechanic, run through it with me and gave me a bearing puller Wink
  Removing broken bleen nipple/How many types of rear calipers? Iaitoo 16 3,137 31-03-2016, 02:25 PM
Last Post: pug306driver
  Rear drum / hub torque setting firemoth 4 994 19-09-2015, 03:06 PM
Last Post: Magenta Sunset
  rear beam removing hubs Matt 17 2,406 26-06-2015, 06:12 PM
Last Post: Piggy
