Threads: 117
3
Car Model/Spec: 1.9 Non turbo estate
Right this ones bugging me so I'm asking for help
My amp was working fine. turned it on last night came on then went off 5 mins later. Turned out the earth had come off the amp something had dell over in the boot and caught the cable. I touched the earth to the terminal and it came on fine so I left it at that thinking ill stick that back on in the morning. So I put it back on and nothing.
I've checked the earth and changed the earth cable. Both the under bonnet fuse and the amplifier fuse appear to be intact.
Threads: 164
25
Car Model/Spec: Gti6
Given 4 thank(s) in 4 post(s)
Deffinately a good earth? tried connecting it elsewhere?
Threads: 117
3
It was working fine up till night was even fine when I touched it to terminal last night but this morning there's nothing at all no lights in amp at all
Threads: 96
7
Car Model/Spec: 306 tractor
a fuse on the amp or power lead?
Threads: 117
3
There is a fuse on both and both appear to be intact
Threads: 131
6
Car Model/Spec: MX5
have you checked the remote lead from the back of the head unit to the amp?
Threads: 226
24
Car Model/Spec: A3 TDi
Check those fuses with a multimeter, could be a dodgy one or could be a ninja fuse lol
Threads: 117
3
Ninja fuse ?
just been told that sometimes the big fuse in the power cable can go and you can't tell without changing it. It goes at the solder joint on the end on the metal strip in the middle
Threads: 117
3
Ill have to look when I get home tonight then I've checked the remote wire that's attached good and solid
Threads: 208
60
Given 5 thank(s) in 5 post(s)
Id replace both fuses as a starting point, if no luck bridge the remote to the live , (this will check if its the rem) if still no good your fuses were to higha amp and you over loaded the and its fooked, simples
Threads: 79
17
Car Model/Spec: Down and out HDi racestate
Do you have the ignition on? Simple i know
Threads: 79
17
Just checking though. If hes expecting life by just connecting the earth and he doesnt have the keys in then he can check it all as much as he wants.
Threads: 117
3
If you mean bridge the remote to the positive on the amp I tried that and it sparks so I've got power there pretty sure it shouldn't spark though
Threads: 226
24
03-05-2013, 01:27 PM
(This post was last modified: 03-05-2013, 01:28 PM by Tom.)
The spark is it making the connection, surely? Are you testing with a multi meter or poking wires and see which spark?
Threads: 117
3
I was bridging the remote to the positive with another wire can't get hold of a multimeter till Tuesday
Threads: 117
3
Sorted I've cleaned the earth up and changed the earth cable it's working now thanks for the help guys
Threads: 2
Car Model/Spec: 1.4 306 meridian fase 3
What wire did u put ur remote one on to on the back of the head unit
