No power to amp - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Interior, Exterior, ICE (https://www.306oc.co.uk/forum/forumdisplay.php?fid=12) +--- Thread: No power to amp (/showthread.php?tid=13460) |
No power to amp - Willo - 02-05-2013 Right this ones bugging me so I'm asking for help My amp was working fine. turned it on last night came on then went off 5 mins later. Turned out the earth had come off the amp something had dell over in the boot and caught the cable. I touched the earth to the terminal and it came on fine so I left it at that thinking ill stick that back on in the morning. So I put it back on and nothing. I've checked the earth and changed the earth cable. Both the under bonnet fuse and the amplifier fuse appear to be intact. RE: No power to amp - rocker8742 - 02-05-2013 Deffinately a good earth? tried connecting it elsewhere? RE: No power to amp - Willo - 02-05-2013 It was working fine up till night was even fine when I touched it to terminal last night but this morning there's nothing at all no lights in amp at all RE: No power to amp - devils_fuel - 02-05-2013 a fuse on the amp or power lead? RE: No power to amp - Willo - 02-05-2013 There is a fuse on both and both appear to be intact RE: No power to amp - Ben Jay - 02-05-2013 have you checked the remote lead from the back of the head unit to the amp? RE: No power to amp - Tom - 02-05-2013 Check those fuses with a multimeter, could be a dodgy one or could be a ninja fuse lol RE: No power to amp - Willo - 02-05-2013 Ninja fuse ? just been told that sometimes the big fuse in the power cable can go and you can't tell without changing it. It goes at the solder joint on the end on the metal strip in the middle RE: No power to amp - Tom - 02-05-2013 Ninja fuse (i just made it up) Fuse that looks fine that actually broke lol hence testing with a multimeter
RE: No power to amp - Willo - 02-05-2013 Ill have to look when I get home tonight then I've checked the remote wire that's attached good and solid RE: No power to amp - puglove - 02-05-2013 Id replace both fuses as a starting point, if no luck bridge the remote to the live , (this will check if its the rem) if still no good your fuses were to higha amp and you over loaded the and its fooked, simples RE: No power to amp - Slam Wagon - 02-05-2013 Do you have the ignition on? Simple i know RE: No power to amp - puglove - 02-05-2013 (02-05-2013, 05:47 PM)PE02KHG Wrote: Do you have the ignition on? Simple i know guessing he has the head unit on to find out its not working therefor the rem from the head unit would switch the amp on
RE: No power to amp - Slam Wagon - 02-05-2013 Just checking though. If hes expecting life by just connecting the earth and he doesnt have the keys in then he can check it all as much as he wants. RE: No power to amp - puglove - 02-05-2013 Fair point i'll give you that
RE: No power to amp - Willo - 02-05-2013 If you mean bridge the remote to the positive on the amp I tried that and it sparks so I've got power there pretty sure it shouldn't spark though RE: No power to amp - devils_fuel - 03-05-2013 dead amp? RE: No power to amp - Tom - 03-05-2013 The spark is it making the connection, surely? Are you testing with a multi meter or poking wires and see which spark? RE: No power to amp - Willo - 03-05-2013 I was bridging the remote to the positive with another wire can't get hold of a multimeter till Tuesday RE: No power to amp - Willo - 06-05-2013 Sorted I've cleaned the earth up and changed the earth cable it's working now thanks for the help guys RE: No power to amp - Richard Dean - 29-10-2013 What wire did u put ur remote one on to on the back of the head unit |
