symptoms of top mounts gone?
Right my near side front wheel has -2 degrees off camber but the other side doesnt, I had the lower arms, p bushes and ball joints replaced and there the right ones and size just abit confused why one side has more camber than the other is the due to top mounts gone?
You could undo the top shock absorber nut and see if the hole has gone oval
on the estate it was wearing hard on the inside of the N/S/F tyre. upon removing the shocks to lower it the top mount bearing was mashed and crushed down on 1 side. Im not 100% but this could of been responsable for tge un even wear i.e camber??? didnt check for camber before but dosnt have any excessive camber now.
so could well be. its only half hour job to wip it out and hace a look?
Ill have a ganda at work tomorrow, migjt just fot the gaz coilovers for now and sell the spax springs and shocks
Think these gone Lol
Replaced 16 quid from gsf lol
Attached Files Thumbnail(s)
  Rear beam symptoms aaron_one 5 954 27-09-2015, 08:12 PM
Last Post: welshpug
Star ball joint failure symptoms no2lurch 10 2,747 21-05-2013, 05:55 PM
Last Post: Danny2009
  Symptoms of buggered driveshaft? Niall 25 7,661 27-04-2013, 10:46 PM
Last Post: Stephen
