17-04-2013, 11:17 PM
Im looking at a set of wheels here that are et38, what width of spacer would I need to fit them to a 306?
Im guessing id need a 20mm spacer?
Cheers.
Cheers.
Wheel Offset Question.
Im guessing id need a 20mm spacer? Cheers.
17-04-2013, 11:30 PM
Should have mentioned they are 7j wide.
17-04-2013, 11:33 PM
Should be fine with 20mm mate providing your beam is ok!
I always use this, you might find it useful. Www.willtheyfit.com
Yea beam is ok, thats a handy website, cheers mate.
17-04-2013, 11:41 PM
No probs mate, might be pretty close on the inside so if you can get 25mm spacers I would as they will be about 11mm closer to the inside of your arches than standard clones with 20mm spacers.
17-04-2013, 11:48 PM
Im still not decided if i'll go for them yet, if i went for a 25mm spacer, would i have much clearance on the outer arch, im right low so i dont want it poking out that much.
17-04-2013, 11:51 PM
Well im running 6.5j at et16 and theres bags of room on the back, the front is pretty close tho
18-04-2013, 12:20 AM
I must check tomorrow what width and offset the wheels i have on at the minute are, cause ive only a couple of mm of gap at the rear outer arch, and the fronts rub the archs when im turning (need a smaller tyre)
Quick question about cyclone wheel bolts | titch | 11 | 2,220 |
06-05-2014, 09:58 AM Last Post: cully |
