Threads: 100
07-04-2013, 05:55 PM
(This post was last modified: 07-04-2013, 06:03 PM by Pompey306mark.)
So just changed the oil ring on the mocal sandwich plate and put new oil lines to the oil cooler.
On the way home the temps never went over 70 and stuck around 50-60 but oil pressure was normally off the gauge 100psi sometimes down to 95psi
Before the change over, normally 95c and and between 50-80psi.
Any ideas? On return to home both the oil cooler and oil filter are hot to the touch.
Threads: 541
124
I take it the 90-100 is psi not c?
IIRC it's a 5bar spring in the pump
Threads: 100
That's right just changed it.
Threads: 30
50-60 oil temp has the plate got a sat? That's running to cold!
Threads: 100
Yea it's a thermostatic one.
Threads: 90
Thats because the oil is running wayyy to cold, and when oils cold its thick, and you get very high oil pressure, the stock reg will let it go above 5 bar when cold, cant cope with the flow, and thats running cold all the time...
Threads: 100
Why is it running cold though? I did not have this problem before we changed the O ring and lines.
Threads: 90
Seems like stat isnt working or something, if you put cardboard over cooler does temp go back up, if so its not opening stat down low...
Threads: 100
07-04-2013, 07:31 PM
(This post was last modified: 07-04-2013, 07:32 PM by Pompey306mark.)
Will have to check, nothing was touched with regards the plate or the stat.
Undid it all changed over the bits and put it back together.
I am getting pissed off with these French cars now.
Threads: 100
08-04-2013, 11:56 AM
(This post was last modified: 08-04-2013, 11:56 AM by Pompey306mark.)
So covered up the oil cooler with cardboard.
Went for a drive.
This is how it stayed.
If I accelerated oil did not get warmer it cooled.
Threads: 90
wtf, does your water come up to good temp? Or is something failing on that letting it just run at <70 all the time...
Threads: 100
08-04-2013, 12:14 PM
(This post was last modified: 08-04-2013, 12:20 PM by Pompey306mark.)
Water is fine, had baking hot blowers all the drive, water temp sat at 85. Like it always has when the system was in good condition.
I have had coolant pressure issues recently.
I was thinking of just emptying all the oil and coolant and starting again, but I have lost interest.
Threads: 131
6
Car Model/Spec: MX5
Threads: 100
09-04-2013, 11:51 AM
(This post was last modified: 09-04-2013, 11:52 AM by Pompey306mark.)
No fitted oil cooler everything was fine.
Fixes stupid O ring to repair a leak, complaining oil is to cold.
Threads: 131
6
Car Model/Spec: MX5
whats strange is you've fixed the pressure in essence by stopping the leak so more pressure is in the system. but its not getting hot. im assuming you've been for a good blast it in?
Threads: 100
09-04-2013, 12:04 PM
(This post was last modified: 09-04-2013, 12:06 PM by Pompey306mark.)
50 mile drive home and around 10 yesterday with oil cooler covered.
It's was the smallest leak from an O ring I doubt that has made it go up by 40+ psi.
Threads: 143
10
Car Model/Spec: Ph3 XUD
Given 8 thank(s) in 8 post(s)
I'm sure you've already checked, but could it be something as simple as too much oil?
Threads: 100
checked the levels, it seems fine.
Threads: 100
Right today removed all the oil and took the plates off.
Changed the oil and filter.
On start up it did this:
5 - 10 minutes say doing nothing.
Threads: 100
11-04-2013, 07:34 PM
(This post was last modified: 11-04-2013, 07:35 PM by Pompey306mark.)
Quick drive to the hill.
Just removed the cardboard from the cooler too
