15-05-2012, 04:18 PM
Would a wilwood conversion from a 106 gti bolt straight onto a gti6??
wilwoods from a 106gti
15-05-2012, 04:32 PM
for anyone who has to look it up like me its a brake conversion kit
15-05-2012, 04:33 PM
I would believe so, as a popular mod on the 106 is to fit either '6 brakes or DT brakes. This would lead me to assume the mountings are the same, so i would hazard a:
Yes ![]() Worth double checking though. ![]() Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
15-05-2012, 04:44 PM
I would guess that the mountings would be the same, only issue you may have is spacing depending on what wheels you'll have on the car
15-05-2012, 04:46 PM
I would also say they would fit.
I know the standard DT brakes as grant said are used as a 106 upgrade as my friend used my old set as spares.. I would assume the fitment would be fine. May be worth chucking Wilwoods an email?
15-05-2012, 04:47 PM
Your running clones right? If so then no... As midnight said, the spacing wouldn't work...
15-05-2012, 04:51 PM
You'd need some 13mm hubcentric spacers, but as said the fitment is the same
15-05-2012, 04:52 PM
Scott Wrote:You'd need some 13mm hubcentric spacers, but as said the fitment is the same To get them under clones? ![]() Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
15-05-2012, 04:55 PM
Yeah dude
![]() The 13mm spacers are around £80 a set I believe...Carl at CG Cars in Leicester used to sell them to go with the fitting kit of the wilwoods.
15-05-2012, 04:57 PM
Interesting. I needed about 50mm of spacing to squeeze those brembos under my clones, and if a stone went in there it woulda been disasterous.
This is a good route for me to start investigating then... Nice one. ![]() Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
15-05-2012, 05:01 PM
Tell a lie, Carl sold the 13mm spacers and you can actually fit them with 11mm spacers
15-05-2012, 05:09 PM
Grant Wrote:Interesting. I needed about 50mm of spacing to squeeze those brembos under my clones, and if a stone went in there it woulda been disasterous. 106 gti will woods are actually smaller than brembos....and better. Bit limited to pads though.
15-05-2012, 05:11 PM
Scott Wrote:Tell a lie, Carl sold the 13mm spacers and you can actually fit them with 11mm spacers 11 meter spacers!!!! Daymn ![]() TEAM CONROD SHITTING RALLYE!
15-05-2012, 05:12 PM
Don't know what you're talking about
15-05-2012, 05:13 PM
Jesus, this is going to be expensive. Are wilwood at FCS? lol
15-05-2012, 05:14 PM
Scott Wrote:You'd need some 13mm hubcentric spacers, but as said the fitment is the same Sorry should of stated that i knew about the spacing issue on clones, as the wilwood the lads run on the 6 forum have the same issue, so a yes on the mountings then? Whooooo got myself some wilwood four pots for the winter conversion
15-05-2012, 06:36 PM
ok boys and girls whilst we are here will 106 coiles fit a 306? I no 205 ones do so worth a quick as me thinks
15-05-2012, 07:45 PM
Yes the106 willwoods will fit but 106 hoses are totally incorrect and standerd hoses won't fit willwoods as they have a taper fitting on the caliper end
Good news is I can supply the correct hoses with the correct fittings at a very good price £28.50 the pair deliverd I supplied the ones used in the group buy on the gti6 forum several years ago
16-05-2012, 09:22 AM
swampy Wrote:Yes the106 willwoods will fit but 106 hoses are totally incorrect and standerd hoses won't fit willwoods as they have a taper fitting on the caliper end Just out intrest mate what will a set up set you back now days?
16-05-2012, 09:42 AM
I Can't get the calipers at a discount but can supply the correct hoses
16-05-2012, 09:43 AM
Could you point me in the direction of new ones?
16-05-2012, 10:12 AM
puglove Wrote:ok boys and girls whilst we are here will 106 coiles fit a 306? I no 205 ones do so worth a quick as me thinks No they won't the 106 strut is one piece with the hub IIRC while the 205 ones are the same design as the 306 just altered slightly ![]() Edit:- 106 front strut
16-05-2012, 12:15 PM
Yeah your not making that fit in a hurry
16-05-2012, 05:10 PM
Give me an hour with a angle grinder and a hammer and i will have them fitted
18-05-2012, 12:01 PM
puglove Wrote:Could you point me in the direction of new ones? Rally design.
Top engine mount repair/reinforcement/chocking for cracked chassis and high powered cars, drive in, drive out, 2 hour turnaround. |
