Threads: 129
11
As some may know i've got an XUD in my 205. I find the engine noise/clatter really loud in my car compared to a 306 as the bonnet sound deadening is waffer thin.
Has anyone tried fitting a HDI cover to their XUD?
I'm running a FMIC so there's not going to be any airflow issues.
I just want it sounding abit less rattly like a modern diesel :roll: well as quiet as I can get it anyways.
Stage 2 XUD Sedan
Threads: 171
46
Doubt it would make much of a difference
To be fair pug did pump out the loud dervs so there isn't much you can do.
Turn the music up? Lol
Threads: 36
18
Car Model/Spec: DT
I like my clattery noisy diesel, and my chav cannon bwarp.
Makes me feel like a rebel.
On the 306 waiting list.
Threads: 129
11
I love the on boost sound revving over 5k from the open filter and straight through to a tiny tiny back box
It's just the idle that sounds clattery, more than most 306's due to the lack of sound deadening
Thinking of putting something like this in plat of the original bonnet under lay
http://www.ebay.co.uk/itm/sound-proofin ... 1621wt_698
Stage 2 XUD Sedan
Threads: 87
31
Probably is down to the lack of bonnet lining, but also check your pump isnt too far advanced because they make a right racket when they are
Threads: 171
46
Could be a good option. Also raising your idle might help too
Threads: 129
11
I think the timings as it should be, never been touched and runs spot on.
I don't wanna touch the idle as i've just got it dead on 1k
Stage 2 XUD Sedan
Threads: 87
31
Well that might be something to do with it  I know it can be helped when your running alot of fuel, but a 1000rpm idle will sound a fair bit louder than most standard ones at like 750/800rpm
Threads: 266
18
Car Model/Spec: 205 DTurbo
Man up mate. Isn't a lot to be done.
Threads: 129
11
I always thought the idle was meant to be 1000rpm :oops:
For some reason the RPM gauge won't read below 1000rpm and having a worn fork bush any lower revs and it's juddery, that will be sorted soon though when the weather clears
Stage 2 XUD Sedan
Threads: 171
46
Iirc mot idle says something like 950 to 1050 lol
Threads: 87
31
Diesels should idle at around 800rpm
Threads: 41
Car Model/Spec: Dtractor
20° static advance for some clatter, get on!!
Threads: 9
19
Dave Wrote:20° static advance for some clatter, get on!!
 and again.............FCS last year, yours sounded like a passing train when it was cold
Threads: 41
lol!!! Oh yeh forgot about that, was was umm about 9° static advance
Threads: 90
Lol wasnt daves a tooth out last year at fcs lol? didnt even realise at the time rofl.
Diesel knock ftw anyway, nothing like the noises of a cold idi on a cold fresh morning.
Threads: 27
20
mi16 it  sound lovely on tickover then ha ha
Threads: 90
I hate petrols, Think ive stalled it everytime i stop at a junction!
Threads: 52
Car Model/Spec: Ph2 Dturbo
didnt your 205 sell on ebay?
Threads: 27
20
darrenjlobb Wrote:I hate petrols, Think ive stalled it everytime i stop at a junction!
ha ha 5k drop the clutch!! wont stall then lol
Threads: 129
11
That wasn't mine, it was a replica model lol.
Hmm i'll give the sound deadening a go and see what happens.
Stage 2 XUD Sedan
Threads: 41
Ive stalled mine from a 5k dropped clutch before  revs leads to a false sence of security thinking you have positive mani pressure... yeh darren it was a tooth out, which is about 8-9° or something
HDi engine cover could well work fella, a lot of the nosie is from the ignition right, which will be deadened a fair bit if you insulate the top of the engine.
Threads: 129
11
Poodle Wrote:HDi engine cover could well work fella, a lot of the nosie is from the ignition right, which will be deadened a fair bit if you insulate the top of the engine.
That's what I thought... Will the throttle arm hit it though?
Stage 2 XUD Sedan
Threads: 41
You get that jammed with govmod... damn wouldnt be good for your engine screaming its guts out
They are noisy because they're single pop injectors, you could piss about with the dynamic advance system and get it flat as hell on idle, or get the bosch that lets advance off with load.
So adjust the mounts so it sits a bit better.
Threads: 41
Yeh well the clatter is just injection happening before TDC, if you adjust the pump so it happens after TDC you get much less power, but its fookin quiet...
