11-05-2019, 03:30 PM
Hi all,
I've had a blow from where the cat joins the centre section for a while. I did presume it was a hole in the cat so I was going to take it off and weld it up but there isn't a hole... Just as well because I can't be arsed taking the cat off!
It's just leaking from the join, not helped by the crumbling flange.
Has anyone used some sort of gasket on this join or should I just gun gum it?
Cheers, Lewis.![[Image: af818355e6e685320a38b3db2edd1522.jpg]](https://uploads.tapatalk-cdn.com/20190511/af818355e6e685320a38b3db2edd1522.jpg)
Sent from my Pixel 2 using Tapatalk
Cheers, Lewis.
