Full Version: Cat to centre exhaust join
Hi all,
I've had a blow from where the cat joins the centre section for a while. I did presume it was a hole in the cat so I was going to take it off and weld it up but there isn't a hole... Just as well because I can't be arsed taking the cat off!
It's just leaking from the join, not helped by the crumbling flange.
Has anyone used some sort of gasket on this join or should I just gun gum it?
Cheers, Lewis.[Image: af818355e6e685320a38b3db2edd1522.jpg]
Sent from my Pixel 2 using Tapatalk
