Threads: 67
Car Model/Spec: 306 Sedan - Ph1 Dturbo
Given 6 thank(s) in 6 post(s)
(05-10-2017, 10:31 AM)welshpug Wrote: if there's nothing wrong with your current lump just use that.
More of a case of needing to keep the car mobile while the engines being built.
And the other reason is i suspect the engine could be breathing heavily as it enjoys pushing oil out despite sorting everything else out around it
Justin_306DTurbo
306 Ph1 Dturbo Sedan
306 Ph1 Dturbo Estate (VNT)
Partner Ph1 (XUD Swap)
306 HDI Stage 3 Estate (RIP)
Threads: 67
Just to throw this out there before i buy new. If anyone has a set of arp's avaliable for sale i now have funds to purchase them
Justin_306DTurbo
Threads: 110
20
Sounds like i could be doing similar to you justin, I plan to build up a fresh engine over the winter.
Threads: 67
(07-10-2017, 07:31 PM)Frosty Wrote: Sounds like i could be doing similar to you justin, I plan to build up a fresh engine over the winter.
Mines just crapping its pants atm. These are still pretty reliable if the block was stronger.
Yours showing signs of fading out too then?
Justin_306DTurbo
Threads: 67
(07-10-2017, 07:56 PM)Frosty Wrote: (07-10-2017, 07:33 PM)dr_jekyll Wrote: (07-10-2017, 07:31 PM)Frosty Wrote: Sounds like i could be doing similar to you justin, I plan to build up a fresh engine over the winter.
Still struggling with the white smoke issue which we think could poss be down to a compression issue.
Been thinking about doing an engine for it for a while, get it all painted up and looking smart etc.
Exactly the same here. White smokes if you toe down after allowing it to sit ticking over or after a long period of not ragging it. Still blowing a small amount of water out aswell.
Just think its all pointing to a tired engine.
Also got so many oil leaks aswell
Justin_306DTurbo
Threads: 128
21
Given 41 thank(s) in 38 post(s)
worth getting a 16v DW10 (110bhp) and giving that a once over before droppig it in?
would start immediately with a better platform.
/Toseland
Threads: 67
(13-10-2017, 10:33 AM)toseland Wrote: worth getting a 16v DW10 (110bhp) and giving that a once over before droppig it in?
Thought mountings different
Justin_306DTurbo
Threads: 67
Tbf ive never done a headgasket so maybe one step at a time first
Justin_306DTurbo
