I recently took this off and replaced it with a Klarius Cat because it had a hole. I have since welded up the hole. I am not a welder! Is this a Peugeot or aftermarket CAT? If it is Peugeot should I put it back on?
I wouldnt sell it for sure as they are getting rare now
they are much better than the ECP cats
I still run a genuine CAT on my 6 which just sailed through its MOT emissions today
if i could fine another genuine i would buy it if the price was right just to keep on the shelf
23-04-2017, 04:06 PM (This post was last modified: 23-04-2017, 04:08 PM by DeeTurbo.)
(22-04-2017, 05:31 PM)RetroPug Wrote: As cully said that's a genuine gti6 cat, worth keeping and worth refitting on the vehicle as it is better than pattern ones.
They snap there very often, I converted the joint to a sleeved fit and welded a flexi section in, but the cat itself is still good.
(21-04-2017, 01:55 PM)KevinTW Wrote: I am not a welder!
We noticed!
23-04-2017, 06:23 PM (This post was last modified: 23-04-2017, 06:25 PM by RetroPug.)
(23-04-2017, 04:30 PM)welshpug Wrote: doesn't need a flexi there as there's one at the top end.
The part that sleeves inside the centre section gives it support, but I found after having converted it to a std. shorter sleeve fit that it snapped. Also my exhaust was moving a lot on sprints.
I think better engine mounts will help to sort this, but I put a flexi there at the time and it did help.
