Poll: Rebuild my beam with negative camber now or later?
You do not have permission to vote in this poll.
Now
0%
0 0%
Later
0%
0 0%
Total 0 vote(s) 0%
* You voted for this item. [Show Results]
Rebuild now or later?
Pretty sure my rear beam is f****d, hell of a lot of negative camber on the offside wheel.
Will re building the beam fix this negative camber?
Along with this can negative camber take the beam past a point where it becomes un fixable?
1999 - Black Rallye A/C
2002 - Silver 206 1.4 HDi LX
Yes it is likely to be worn past a rebuild if it has visible excessive camber.
You wont tell till you've stripped it apart how much of it you can re-use, at worst you'd need a crossmember and rebuild kit.
Okay adding to this I don't think I can be bother to rebuild the beam myself, given I don't have access to a press to re fit the trial arm shafts, also the idea of spending £100 on the rebuild kit to find out it I still need a cross member tube doesn't appeal to me.
I think i'm going to buy a refurbed beam from IM Axle or somewhere similar £205 with a 2 year warranty doesn't sound too bad to be although they would take away my axle but unless someone on here has a decent gti-6/ rallye beam I could have I don't think its a viable option to rebuild my beam myself.
Whilst changing the beam is it worth changing to solid beam mounts? I want to track the car at some point in it's lifetime and even if I don't I'm not fussed about cabin noise or reduced comfort too much as I really don't do massive journeys in the car.
Stef rebuilds beams. I would choose him over IM Axles. His prices are reasonable as well.
I do beams too but Stef is fairly local to you if you're in Somerset.
I would be very sceptical of a £200 beam given the parts to rebuild them properly IF you get decent quality parts is around the £100 mark, that's without a good core unit and Labour.
Okay thanks guys I'll get onto Stef is this Stef205 or something similar to that??
Stef205 is the one.
Thanks for the recommendations guys appreciated as always Smile
Ive spoken with josh hopefully we can work something out.
90' 205 gti6 supercharged
05' Evo 9 IX GT
Team eaton.
