Rebuild now or later? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: Rebuild now or later? (/showthread.php?tid=35642) |
Rebuild now or later? - wainwrightj - 26-02-2017 Pretty sure my rear beam is f****d, hell of a lot of negative camber on the offside wheel. Will re building the beam fix this negative camber? Along with this can negative camber take the beam past a point where it becomes un fixable? RE: Rebuild now or later? - welshpug - 26-02-2017 Yes it is likely to be worn past a rebuild if it has visible excessive camber. You wont tell till you've stripped it apart how much of it you can re-use, at worst you'd need a crossmember and rebuild kit. RE: Rebuild now or later? - wainwrightj - 27-02-2017 Okay adding to this I don't think I can be bother to rebuild the beam myself, given I don't have access to a press to re fit the trial arm shafts, also the idea of spending £100 on the rebuild kit to find out it I still need a cross member tube doesn't appeal to me. I think i'm going to buy a refurbed beam from IM Axle or somewhere similar £205 with a 2 year warranty doesn't sound too bad to be although they would take away my axle but unless someone on here has a decent gti-6/ rallye beam I could have I don't think its a viable option to rebuild my beam myself. Whilst changing the beam is it worth changing to solid beam mounts? I want to track the car at some point in it's lifetime and even if I don't I'm not fussed about cabin noise or reduced comfort too much as I really don't do massive journeys in the car. RE: Rebuild now or later? - Eeyore - 27-02-2017 Stef rebuilds beams. I would choose him over IM Axles. His prices are reasonable as well. RE: Rebuild now or later? - welshpug - 27-02-2017 I do beams too but Stef is fairly local to you if you're in Somerset. I would be very sceptical of a £200 beam given the parts to rebuild them properly IF you get decent quality parts is around the £100 mark, that's without a good core unit and Labour. RE: Rebuild now or later? - wainwrightj - 28-02-2017 Okay thanks guys I'll get onto Stef is this Stef205 or something similar to that?? RE: Rebuild now or later? - Poodle - 01-03-2017 Stef205 is the one. RE: Rebuild now or later? - Stef205 - 01-03-2017 Thanks for the recommendations guys appreciated as always ![]() Ive spoken with josh hopefully we can work something out. |
