Threads: 29
Given 7 thank(s) in 7 post(s)
You can drop the sub frame or modify the sub frame by cutting and adding strength else where.
Didn't know the ML bolted up to a XU.
Threads: 14
Given 6 thank(s) in 6 post(s)
just a quick up date the sub frame has been trimed up and all fits with pinnkey fingers width around the drive shaft cups and a 2002 406 hdi lower engine mount to get it to what i think is the right angle. so i just need to get the trigger pattern put on the flywheel and it should run, then thers the clutch and gear lever.
Threads: 42
28
clutch and gear lever is relatively simple, 206 master fitted to adapted d9 406 or c5 pipework and slave cylinder.
shifter is essentially remove all the original rods and fit the cable setup, mak some brackets to hold the box up
Threads: 14
so weekend update flywheel is off at the enginers getting the trigger pattern put in and the drive shafts are going to be put together tomorrow and the left engine mount will be started
Threads: 14
just a small on today is up hand hainging free best bit is i've still got full left hand lock
Threads: 14
things have started to flagg, i'm wating for stuff to be done by others
Threads: 29
Interesting about the no rubbing. In a 205/309 it does catch a little, nothing like a 6 speed though.
Threads: 14
i will get some pics up of the wheel clerance once the traking and stuff is sorted out
Threads: 14
things are moving forward at the enginers so i will be getting back on this soon
Threads: 371
29
Car Model/Spec: ford fiesta
Id say it wouldnt be to much of an issue as long as you stregthend it up again. Personally though ive seen a few hydro setups now and none have had to cut that bit
Threads: 42
28
what cylinder are you using? I think a 206 cylinder might fit in the gap and does have a nice 2 bolt flange.
Threads: 90
54
Problem I found was there just wasnt room there behind the motor to put a cylinder directly on the bulkhead.... Although things may differ with other motors. But mine is at 15 degrees and still not nearly enough room there...
Threads: 14
04-07-2017, 05:15 PM
(This post was last modified: 04-07-2017, 05:21 PM by madmadmax.)
looking at the 307 and corsa c cylinder atm but any sugestions are welcome, i think the 206 cylinder is a littel to big
Threads: 42
28
307 cylinder is far bigger and a much more awkward fitting type to use, the reason a 206 slave is suggested is they have a shorter body and a 2 bolt flange.
Threads: 90
54
I used a 206 cylinder on my conversion and has been working great so far...
Threads: 14
i will post up some pics soon as to what has been happing slowly and what i did with the clutch master
