Threads: 6
Car Model/Spec: 306 hdi estate stage 2
Country:
306 hdi
Stage 2
Its boosting at 18psi
Been told it turned up
If i get a boost controller
What would i turn it up to and still be safe ??
Threads: 202
58
06-11-2016, 11:48 AM
(This post was last modified: 06-11-2016, 11:49 AM by Jonny81191.)
I used to run 21 psi on my ko3 hdi, stage 2 map and intercooler with a straight through. You will reduce the life of the turbo though, I'd recommend fitting something bigger such as a Gt2052 or an IHI rhf5. Alternatively, you can go down the vnt route and fit something like a Gt2056v There's loads of information in various project threads and the guides section if you want to read up on it.
Threads: 110
20
Echo pretty much what MY95 said, but i would try and get your turbo up to about 20 psi on the stage 2.
