fitting a front suspension ball joint
So I need to replace my ball joint, can fit the three bolts as is obvious.  But the other end, wondering what method to remove and refit, any tools needed or is itma simple pop out and in?
Cheers for the help in advance.
remove clamp bolt, pull arm down to release pin from hub carrier.
pushing inwards on the disc can help.
always use correct torque settings.
(28-10-2016, 08:44 PM)welshpug Wrote: remove clamp bolt, pull arm down to release pin from hub carrier.
Thanks, hoped it was that easy
Tbh i would undo the 3 arm-bj bolts first and separate that and then split the bj with a splitter if you've got one, means you don't end up fighting the arc of the arm to try and disengage the bj. To reinstall wedge the arm in position with a lever bar while you get everything positioned.
  Front top spring suspension Welshy_Pete 4 4,026 21-04-2018, 09:52 PM
Last Post: Mighty306
  Ball joint/ Hub to strut pinch bolts Uberderv 7 5,790 04-01-2018, 11:40 AM
  front suspension johnnygomez 5 4,015 10-12-2016, 12:36 PM
Last Post: johnnygomez
